Need Glow Plug Help on L3010
   / Need Glow Plug Help on L3010 #1
HarleyBob
Puget Sound, WA.
I have a L3010. It is starting fine, but the glow plug light comes on and stays on after starting.
Is their both a Relay and a Controller? What is a Timer?
Does anyone have the part numbers for these? I am not finding both relay and controller at Messicks, just a relay.
However on eBay there is a "Timer" unit for sale when you search Kubota glow plug timer.
Where are they located...for replacement?
Should I replace both?
I still need some help getting the correct part numbers. I could replace Controller first and timer first. Looks like they are two separate items.
Relay would be last...or just replace all three, since I have to open up dash anyway?
   / Need Glow Plug Help on L3010 #4
I had to replace the controller a couple of years ago for the exact symptoms you are describing. The Kubota tech told me it was very common, he knew exactly what was wrong when I told him the lights wouldn't go off.
So far I have ordered the timer....dealer said that its almost always timer...then controller....
Kevin, did you do the "controller" or "timer?"
   / Need Glow Plug Help on L3010 #6
The controller.
Kevin
   / Need Glow Plug Help on L3010 #7
I had a similar problem - It was a bad controller.
John Deere X300 Riding Lawn Mower (A44391)
John Deere X300...
Case IH 455 Round Baler (A46877)
Case IH 455 Round...
2012 UTILITY VS2RA 53FT REEFER TRAILER (A43004)
2012 UTILITY VS2RA...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A44572)
2022 Chevrolet...
2016 Ford F-150 Pickup Truck (A44572)
2016 Ford F-150...
Godwin CD100S Dri-Prime S/A Towable Dewatering Pump (A44571)
Godwin CD100S...
