Need Glow Plug Help on L3010
   / Need Glow Plug Help on L3010 #1
HarleyBob
Puget Sound, WA.
I have a L3010. It is starting fine, but the glow plug light comes on and stays on after starting.
Is their both a Relay and a Controller? What is a Timer?
Does anyone have the part numbers for these? I am not finding both relay and controller at Messicks, just a relay.
However on eBay there is a "Timer" unit for sale when you search Kubota glow plug timer.
Where are they located...for replacement?
Should I replace both?
I still need some help getting the correct part numbers. I could replace Controller first and timer first. Looks like they are two separate items.
Relay would be last...or just replace all three, since I have to open up dash anyway?
   / Need Glow Plug Help on L3010 #4
I had to replace the controller a couple of years ago for the exact symptoms you are describing. The Kubota tech told me it was very common, he knew exactly what was wrong when I told him the lights wouldn't go off.
So far I have ordered the timer....dealer said that its almost always timer...then controller....
Kevin, did you do the "controller" or "timer?"
   / Need Glow Plug Help on L3010 #6
The controller.
Kevin
   / Need Glow Plug Help on L3010 #7
I had a similar problem - It was a bad controller.
2025 Wolverine EX-66-78L Pallet Fork Extensions (A47484)
2025 Wolverine...
Kubota D902 Engine (A47809)
Kubota D902 Engine...
2025 Wolverine PFF1-13-45W Pallet Fork Frame (A47484)
2025 Wolverine...
Rear Tractor Tire w/ Rim (pair) (A47809)
Rear Tractor Tire...
2010 Chevrolet Equinox SUV (A44572)
2010 Chevrolet...
2025 AllMetal K0608 UNUSED Metal Site Fence (A47484)
2025 AllMetal...
