Need help buying single cup coffee maker
   / Need help buying single cup coffee maker
Here's a product review of the Cuisinart (made by Keurig to Cuisinart specs) coffee maker the wife bought. It truly is an industrial type model and wife loves it. It has none of the plastic taste of Keurig that others referred to and worked first time, every time. We can put any pod type coffee unit in it and no problem. Wife also bought a coffee basket so she can grind her own beans and that works perfect as well.
You can't go wrong with this coffee maker. It's pricey, but worth it.
Cuisinart(R) Keurig(R) Brewed Single Serve Brewing System - BedBathandBeyond.com
   / Need help buying single cup coffee maker #62
The easiest and best tasting single cup of coffee I've found is made with a coffee bad in the microwave. Folgers is the only brand I've found lately. The coffee smells delicious too.
   / Need help buying single cup coffee maker #63
My neighbor has one of these. She bought it to replace her Keurig that went bad. No one wants the Keurig 2.0 machine that only brews the Keurig cup. If my Keurig machine goes bad, it will be replaced with a Cuisinart machine also. I have an assortment of K-cup pods that I never use. I bought some of the reusable plastic pods and grind my own beans and blend with commercial ground coffee to make my special blend. It is much better than any of the K-cup pods that I have tried.
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
Galvanized steel Fence (A53424)
Galvanized steel...
40ft Sea Container (A52384)
40ft Sea Container...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
