Need help finding a pto driven water pump.
   / Need help finding a pto driven water pump. #11
Buy an old fire truck; cheap and you will get a nice pump with not a lot of hours on it.
   / Need help finding a pto driven water pump. #12
Why would you want to tie your nice tractor to a water pump? So you can walk back and forth? Maybe you have a few spares...
The main reason for the pto pump is reliability. The place that it will be used to flood is a place that only a tractor or an atv can get to. The intention is to run the pump 24/7 until the flooding is finished, then add water as need to maintain level. And yes, I do have more than one tractor.
   / Need help finding a pto driven water pump. #14
TerryJ
After pumping many basements with the volunteer fire company you will have a problem with debris on the suction strainer.
We started using some home built jet pumps for low lifts an 8" piece of pvc sewer pipe with a rope through it with a fire hose from the truck tied to the hose fastened about 1 foot in side the lower end. These worked great for large areas were we didn't have to move around a lot.
We could run 3 or 4 of these with one truck it dose take pressure on the hose ~ 100psi but with one 1000gpm truck you could move 3-4000 gallons of water pipes passed the debris right through them (leaves and other small stuff)
We took suction for the truck off a area with less debris to keep the strainer clean
tom
Tom,
Thanks for the input, but debris is not a problem as I will be pumping from a clear running creek (some would call it a small river) with a mud/sand bottom. I pump from it now with a 4" Honda portable with no problems, strainer is supported about 1' off bottom. I just need something with alot more volume.
   / Need help finding a pto driven water pump. #16
I have a Hale pto pump 550 gpm on a trailer that will do the job for you.
Model 40FC9-5R550
It was originally used in an field irrigation system. Manually primed. Once it catches, get out of the way....
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
