Need help for seat time!
   / Need help for seat time!
You know, I have not messed with that knob since I bought the thing. I was looking at that seat assembly and it looks fairly complicated in the way that it flips up. The engineers weren't thinking of adding air. I'll check the knob. You are probably right that that e-bay seat was replaced with air..good call.
   / Need help for seat time! #12
When you break down the change over it isn't real complicated, you need to preserve the proper seat height with operator off the seat and you need to preserve the rear most seat position in order to engage the rear position seat lock.
When swapping out the seat platforms from spring to air ride if the new platform is too low then you can shim it with washers to raise it up. If the new platform is too high but within an inch you could push down on it to get it to latch in the rear position.
Setting the seat up to latch properly in the rearward position is easy to do, flip the seat to the rearward position and latch it in place. Make sure the platform is in the rear most position, then mark the seat mounting to attach to the platform.
Just a guess but I would think the seat platforms are very close in height and should be easy to swap out. If you have a lot of back problems this might be a real help for you. Well worth the money imo. A little measuring and research on your part and you should be able to get a good idea what will work.
I figured out why I never fuss with my seat adjustment. I don't have one. Given that my 110 is almost ten years old, I think there has been an upgrade. Yall think a newer seat would help?
   / Need help for seat time! #14
I wouldn't guess that it'd hurt.... :D
AKfish
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X8JD476306 (A51572)
2018 Peterbilt 389...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
