Need help getting shear bolt out of driveshaft
   / Need help getting shear bolt out of driveshaft #11
This exact thing just happened to me. Is this common? Am I doing something wrong for this bolt to break?
   / Need help getting shear bolt out of driveshaft #12
The shear bolt is supposed to break in you put too much strain on drive train. It protects the more expensive parts,better to replace a $.89 bolt than a $400 gear box.
   / Need help getting shear bolt out of driveshaft #13
when the blades of the bush hog, hit something solid and hard. the blades can instantly stop. and all the power / shock can be transmitted back to the gear box and tractor. the shear pin, is there to let the PTO shaft "spin" and bust cut/shear the bolt. so the power / shock can NOT be transmitted back to the tractor. and to protect the gear box on the bush hog.
as others have said, get to strong of a "shear pin" and you damage the gear box on the bush hog, or really get into some expensive repairs on your tractor.
if you go with a weaker "shear pin" the pin will shear way to quickly every time you hit something, and you will have to replace them non stop.
if you are replacing the shear pins non stop. maybe you are trying to run over stuff that you shouldn't be running over. and the rotatory cutter just not meant to handle. or you are running the blades into the dirt, or into logs, or rocks or something.
the manual for the rotatory cutter / bush hog or other 3pt hitch implement you are using will state what size "grade" of bolt to use as a shear pin.
you can get "slip clutches" that can replace "shear pins" on some 3 pt implements. when slip clutches are properly adjusted, they can be a easy way to keep on going, without having to replace shear pins.
slip clutches when bought new, need to be "burned" errr allowed to slip. to remove the "new-ness off of them" so the operate properly.
   / Need help getting shear bolt out of driveshaft #14
As boggen said, if you have a slip clutch, which is preferred for a bush hog type cutter it will slip instead of breaking the bolt.
PTO shafts with slip clutches are more expensive than bolt only, but very worth it if you are going to do any heavy cutting.
A caution, if you add a slip clutch, your present PTO shaft may have to be shortened.
   / Need help getting shear bolt out of driveshaft #15
You guys are lifesavers! I used a punch and a hammer and it came out very easily. I think I might be smart enough to figure out how to put the new bolt in. I am not very mechanically inclined especially on stuff I have never used before. When I told the john deere salesman I didn't know a thing about tractors I wasn't lying. I see that small tool box on my 1026 is going to get full quick.
Well, Dave, you came to the right place if you are a rookie. I, compared to many here, am still a rookie a few years into it. When I first found this forum and was considering buying a tractor I lurked for quite a while and when it came time to register and post to ask questions I had to come up with a descriptive handle. Hence my AHNC name. All Hat No Cattle. Experience wise I'm still All Hat. The Cattle part may come, but it will take time and more patience from the guys here!:thumbsup:
Good luck with your rig!
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A54607)
2017 CENTAURO...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
