Need Help - grounding rod install
   / Need Help - grounding rod install
Trust me. I tried. Alway need a new tool. Wife said I needed the excercise more
   / Need Help - grounding rod install #24
I think I would have went back with PVC piping for the well. My Dad had one put down 40+ years ago and it is still pumping from that 2" line. Even the pump point is homemade by the well guy. Just a 5 foot section of pipe that he took a hacksaw and sawed about 1/3 thru from each side alternating the holes. He then poured crushed stone down the drilled shaft to settle around the "pump point". It would fill a 150 gallon tank in 3 minutes which is all the capacity the well pump had.
   / Need Help - grounding rod install #25
James, that video was interesting about the ground rods and depth.
   / Need Help - grounding rod install #26
Yes it was enlightening. If anyone had asked me, putting 120 volts direct to a 10 foot ground or even a 50 foot ground rod, would have popped a break, but looks like all it did even at 50 foot was warm up some earthworms.
   / Need Help - grounding rod install #27
Some interesting tests on the effectivness of ground rods at various depths etc.
https://www.youtube.com/watch?v=Yg6G5VUSsWA
Interesting never seen a comprehensive test like that with results and how/why/what was done.
I put that into my YOUTUBE channel for future ref... People at work were going crazy over kill on grounding wire size just Friday and I knew better than what they were doing but the new guy can't raise waves...
Mark
2005 Holiday Rambler Alumascape Travel Trailer (A48082)
2005 Holiday...
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
2012 BMW 528i xDrive AWD Sedan (A48082)
2012 BMW 528i...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
