Need help identifying this vintage heavy duty JD offset disk
   / Need help identifying this vintage heavy duty JD offset disk #1
exiled cheesehead
Hi Everyone,
Thanks to the first 2 responses. I have deleted the other picture, added my own, and retyped the post. Hope this helps with the ID. Exiled
I have this older JD offset disk that is very heavy duty. All it has for markings is the words "John Deere" on it. No model or serial number plate anywhere. I need to get a set of new bearings for it, so I need to figure out the model number. I have attached 6 actual photos of the disk. The first 3 show it from different vantage points and the last 3 show the bearing housing, which is also the attachment point to the frame. Please double click on the thumbnail photos to enlarge them.
JD Disk 1.jpgJD Disk 2.jpgJD Disk 3.jpgJD Disk 4.jpgJD Disk 5.jpgJD Disk 6.jpg
Based on what I have found elsewhere, I think this disk is either a:
1. John Deere Killefer HD offset disk
OR
2. John Deere WH series offset disk
Can anyone help????
Thanks in advance.
Exiled
   / Need help identifying this vintage heavy duty JD offset disk #2
A larger picture might help others see more detail.
   / Need help identifying this vintage heavy duty JD offset disk #3
Not the answer you were looking for, but if you can remove the bearing, take it to a bearing specialty store. They will measure it and order you a exact replacement.
Thanks for the input. I have updated the original post with more photos of the problem disk.
Thanks
Exiled
   / Need help identifying this vintage heavy duty JD offset disk #5
There is normally a part number on the bearing itself that a bearing supply house will match up and it will be much cheaper than going to John Deere.
   / Need help identifying this vintage heavy duty JD offset disk #6
I just bought that exact same disc this past Saturday, a heavy beast indeed. Mine still has the model and serial number tag on it, I will see if I can read it when I get home tonight and post back if I can.
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
2014 Ford Expedition SUV (A55853)
2014 Ford...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
