Need help installing block heater in BX
   / Need help installing block heater in BX #11
Yes I installed the lower heater hose unit and it worked fine. You just have to be very precise on where you cut the lower radiator hose to do the installation.
I ordered the lower radiator hose unit. Things do look pretty tight under there. oldnslo, you said to be "very precise" on where to cut. Is there a particular place to cut the hose, or do you just try to eyeball it so you have the most room on either side once you insert the heater? Do you remember if you removed a small section of hose or just made the cut and slipped in the heater?
   / Need help installing block heater in BX #13
If & I repeat IF I remember correctly the kit from Kubota had pretty good instructions. What I did was read the instructions and then held the heater up next to hose and marked the hose where it should be cut. You have to remove a short section of hose to install this. Also the direction the power cord is rotated or it will rub on the plastic shroud
Appreciate all the good responses. If I am able I'll get to it this weekend and post a few pics.
   / Need help installing block heater in BX #15
Any progress/pics? I'm interested in doing the same with my BX1860...
Thanks,
wrooster
Hi wrooster. I forgot I promised an update on this thread. I started a new thread detailing my installation here: http://www.tractorbynet.com/forums/...ng/352379-radiator-hose-heater-kubota-bx.html
FWIW, I originally ordered this heater from Amazon: Amazon.com: Kat's (16400) 1" Lower Radiator Heater Hose: Automotive
I thought it would be the same as the Kubota product but after getting it, convinced myself it was physically larger. Given that the space is so tight, I ordered one through the Kubota dealer. Mistake! Paid more than double and it is exactly the same! Special order so couldn't be returned. It's not even a "Kubota" part - it's Zerostart, an aftermarket like Kat's. Returned my Amazon heater, but would never have ordered from the dealer if I knew I would receive the same thing (for more than twice the price!). Good luck.
   / Need help installing block heater in BX #17
I use a magnetic heater. Just stick it to the oil pan. Works great.
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2017 International Rosco Maximizer 3B 1,900 Gallon Asphalt Distributor Truck (A52377)
2017 International...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
