Need Help. Kioti CK3510se or DK4210Se or LS xr4140
   / Need Help. Kioti CK3510se or DK4210Se or LS xr4140
Thanks all! Worst part is waiting for it to show up now! And it sure would have come in handy today moving about 600 lbs of lumber.. My back is not happy with me tonight..
   / Need Help. Kioti CK3510se or DK4210Se or LS xr4140 #12
I have a CK40 and it is a workhorse for sure but I will hopefully be upgrading to an NX in the future. Good choice and Congrats!!!
   / Need Help. Kioti CK3510se or DK4210Se or LS xr4140 #13
SMorris,
Congrats on your purchase!
Chat with your Kioti dealer about a major issue with the backhoe, specifically the rear mounting bracket and the associated mounting hardware. Currently the rear main bracket is an "L" shape that mounts both to the underside of the rear axle housing as well as to the bolt bosses for the PTO shield. Kioti is having a problem with that bracket angle being welded obtuse to the mounting angle. It's not sitting flush to both plains leaving a gap between the pto boss surface and the bracket. The bolt package for the bracket is also wrong. The bolts are not long enough. Kioti didnt take into account the thickness of the bracket when sizing the length of the bolts in the mounting kit.
Without divulging too much info, I found this information out painfully hard.
Currently, Kioti is having some computer issues with the regen system. Apparently, with the 2018 model, there is a CPU change for the emissions program causing the computer to think a regen is necessary when it's not. It forces the motor into limp mode until you manually regen. My tech is working with corporate on this issue. My machine went into limp mode 4 times by 40 hours and it wouldn't correct until i performed a manual regen at 40 minutes each time.
Regardless of hiccups, the NX is a nice tractor line.
Steve
Thanks for the heads up! I passed that info along to my dealer. Will see what he says.
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
