Need help on john deere L120 lawn tractor
   / Need help on john deere L120 lawn tractor #1
lenny180
hi guys-i am having a problem. L120 is 3 years old and has 47 hrs on it. Starts up strong and runs that way for half hour then it just doesn't sound as strong and seems to bog down when cutting. i have given tune up and replaced fuel filter,fuel pump and i don't know what to do. i was gonna take it somewhere but didn't yet. any suggestions??? thanks
   / Need help on john deere L120 lawn tractor #2
First welcome aboard.
You need 3 things for a good running engine, compression, fuel and properly timed spark. 2 things come to mind. Could be the spark coil overheating or loosing compression when warm.
Give this a try. When cold, take the spark plug out and see what kind of spark you get. Run a compression test. Use it until you notice this 'bog down' condition. Recheck the spark and see if it is the same quallity of spark and retest compression. That should give you a direction to pursue to correct your problem.
Thank you Charlie. I will do that this weekend. hopefully is nothing major:)
   / Need help on john deere L120 lawn tractor #4
I've got the same mower and when I had 52 hours on it (now have 150) it would bog down just like your problem. Do this! Loosen the fuel cap while its running and see if its better. I'll bet it is!! My problem was that the fuel cap breather hole was plugged up. Just unplugged it with a piece of wire and all is well. Give it a shot. Sure won't take long to find out.
Let me know how this works for ya!!
Thanks,i'll try that also.hopefully that's it.It still is a baby /forums/images/graemlins/grin.gif
I finally found out its the iginition coil. the one plug has no spark. The other one is good. Is that a part i need to order or can i go in and pick one up??
   / Need help on john deere L120 lawn tractor #8
Just a thank you for the heads-up on the gas cap vent plug clogging. This saved me a lot of bucks. The L120 would run for about 15 min just fine and then the engine started cutting out . Let it sit for a couple hours and it would start again. The manual has you check for clogged fuel filter and a couple other items. Tried everything in the manual and the engine still cut out after about 15 min. I finally read this tread and went out to the mower to try the gas cap. Soon as I unscrewed the gas cap and heard the vac release I knew you were right. Works great now.
Thanks to all.
   / Need help on john deere L120 lawn tractor #9
I know these are old posts but right on anyway. I had same problem with L120 only mine has adjustable vent on cap which had become screwed all the way in. opened it and problem was fixed. Thanks much for the great advice.
Jerry
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
1779 (A51248)
1779 (A51248)
Hose Reel (A53424)
Hose Reel (A53424)
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
