Need help ordering new hydraulic couplings
   / Need help ordering new hydraulic couplings
I went to a local hydraulics store and was able to get the exact same couplers. They seem to be working well with my existing remotes. I was also able to get the 1/2" to 1/4" adapters. They aren't working so well. The leak badly on the 1/2" side where they connect to the hose. The 1/4" side that connects to the coupler is fine. I've tightened it down a lot and am afraid to go any tighter. Do I need to use tape or dope? The one thread I read on that topic just left me more confused.
The adapter is Parker part 0201-8-4. You can find it and its specs on the following catalog page:
It says it is 1/2-14 NPTF, which is what my hose also claims to be, so I assume it is the right part. Any suggestions on how to resolve the leak?
I did a bit more research. From what I've read, NPTF is designed to not need any type of sealant, whereas NPT does need a sealant (mine is NPTF). Also, reuse of NPTF connectors is not recommended due to the deformation that happens during tightening, but if reused, then a sealant is recommended.
I'm a bit unsure how to proceed. It seems I have the right parts as they are both NPTF. Is my leak due to under-tightening or over-tightening? My guess would be the latter, so maybe the only hope at this point is to redo the connection with teflon tape.
   / Need help ordering new hydraulic couplings #13
Talk to Kenny at Boltonhooks.com
For the most part I think I have the leaking resolved. I redid the fittings using teflon tape. Initially results were pretty good, but there was a slow leak with one of the fittings, maybe a drip every 5 seconds. Still, a vast improvement over the constant flow I was seeing before. I then tightened it up a bit, and it got a lot worse. So I redid it again, this time using a bit more tape (maybe 5-6 wraps instead of 3-4), and this time didn't tighten it as much. That seems to have worked really well. There might be a very slow leak, like a drip ever few minutes. I'll keep an eye on it. If it becomes problematic in the future, I might just have the hoses redone with 1/4 fittings so I don't need the adapter. Fortunately this leaking will only be an issue for the week or so a year I'll have my flail mower out, since that's the only time these hydraulic hoses will be attached.
   / Need help ordering new hydraulic couplings #15
Unless you're careful applying it, small bits of tape can end up in the hydraulic system.
I have had good results with LocTite 545, which is made for hydraulic NPT fasteners. Clean the threads well and let it cure for a day before using it.
Yes, I was aware of this. I applied the tape a couple of threads below the tip, and also made sure I wrapped in the proper direction.
   / Need help ordering new hydraulic couplings #17
If the tape fails, you can try loctite 545 but let it set up before hitting it with pressure
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
12'x20' High End Carport (A53316)
12'x20' High End...
2012 Ford Escape Limited SUV (A55758)
2012 Ford Escape...
Hose Reel (A55787)
Hose Reel (A55787)
CFG Industrial MH12RX (A53316)
CFG Industrial...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55301)
PENDING SELLER...
