Need Help: Precleaner for Ford 5900
   / Need Help: Precleaner for Ford 5900 #1
Big_Lug
Jennings,LA
Case IH D40
Can anyone out there give me an idea or suggestion to replace the screen inside the canister for the oil bathe air filter system" I hope I'm making sense, this is a friends tractor". The New Holland dealer wants $500 plus dollars, they say you have to buy the whole metal canister. What happened was his screen inside of the canister came apart. Any suggestions would be appreciated.
   / Need Help: Precleaner for Ford 5900 #2
You should be able to get a new piece of screen cut it to fit tight in canister then take a mig welder and fasten it in
I had suggested that, but he said it would be too hard to replace the screen inside the canister. I was hoping someone might have a used or salvage tractor parts place I could get a used one from.
   / Need Help: Precleaner for Ford 5900 #4
Any way you could just remove the entire filter housing and install a aftermarket modern filter/housing. Stop by your local International truck dealer and ask to look at their filter catalog. In the back is a huge section of filter housing's. Name the length, diameter and inlet/outlet port size and they will have one to replace it with. Would probably be about 1/2 the price or less of the one NH wants to sell you one for. I use these type filter/housing's all the time to upgrade and replace ones on tractors and mobile equipment. Nice thing is you can upgrade your system by getting a filter housing with a much larger filter element that will last alot longer than the original one. Worth checking into considering the cost of a new one from NH.
Dieselpower, I sure thank you for your advise. I will tell him.
Man, thanks alot whitetiger. I could not ask for anything better than that, part # and all.
   / Need Help: Precleaner for Ford 5900 #8
You can also buy used filter housings.. cheap too. There are places that sell the metal mesh. Most of the times it is held in with a snap ring.. no need to 'mig' it in.
I have the address to the outfit that sells the oil bath metal mesh.. etc.
soundguy
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
FUEL CELL (A58216)
FUEL CELL (A58216)
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
