Need help putting formica on my workbench
   / Need help putting formica on my workbench #11
Yes, I use masonite too -- works well as a "beater" bench top surface.
My current workbench top starts with 1" MDF for weight/thickness, then a layer of 5/8" plywood with one good finished side (facing up) that was laminated with Roo-Glue and screwed down with a bunch of drywall screws. Then I toss a sheet of masonite on top to take abuse, using no fasteners. I put edging around the table that sits about 1/8" higher than the plywood to keep the masonite from sliding around.
The only problem I had with the masonite was when I spilled a can of paint. Side story: I had just enough leftover green paint to use on my daughter's playset without having to buy any new paint, but then spilled most of the can shaking it after I had already loosened the lid. Lord knows how I managed to do that, but anyhow, I got a big puddle of green paint on the masonite, and ended up dipping my brush in that puddle to paint her playset. By the time I was done, the moisture in the paint caused the masonite to pucker quite a bit. It went back down for the most part, but isn't perfectly flat like it was before the spill. I also ruined a good work shirt and pair of work shorts, which I still wear but they are not too comfortable anymore....
   / Need help putting formica on my workbench #12
I would use tempered masonite. A little tougher. have seen tempered masonite that had 2 shiney sides. Great stuff, very hard. I don't know where to find it offhand.
   / Need help putting formica on my workbench #13
for a workbench, I just use plywood with one good side. I drill holes into it and I like to screw into it to hold things in place while working on it.
If you want to use Formica, first I cut it close to the right size with tin snips. I like to have an inch or so extra, then I apply the contact cement to the wood and the Formica, let it dry, then put it in place. Just stand it up and get it tight against the back wall, then lower it down, and roll it. Then use a router bit for trimming Formica to get the edges perfect. Remember that the bit is turning in a certain direction and it will cut better going one way then the other way. Practice to see which way works best for you. You wont be able to get the router all the way into the corners where it meets the wall, so use the tin snips to cut it as close as you can, then use a sheetrock knife to get it closer and if you need to, use a file to make it perfect.
Eddie
   / Need help putting formica on my workbench #14
I agree on the Masonite. I glued and screwed it to 3/4" plywood over 20 years ago and then added a 3/4" x 5/8" piece of edging to the front of that. It has held up great and I like the surface. Smooth and hard, and if I screw through a piece of wood into the surface, I won't damage it like it would with laminate.
Ditto here. You can always add a coat or 3 of Poly if you like.
   / Need help putting formica on my workbench #15
Yep, that's what I use. 1/4" tempered, shiny on both sides.
   / Need help putting formica on my workbench #16
I use 1/4 inch tempered hardboard. I also screw on a piece of 1/4 inch thick angle iron to the side of the table to hold the hardboard in place. It makes a great place to form bends in sheet metal projects.
FYI, Masonite is a brand name of hardboard.
   / Need help putting formica on my workbench #17
10 gauge metal formed by a brake (actually were a miss bent truck box) have a 24 inch back splash and a nice full formed edge,
just a few small holes for a few screws,
   / Need help putting formica on my workbench #18
The last few I built have been with Melamine for the top & shelf. So far they are holding up good one and 4 years on them. One scratch cut thru but underneath is holding up well. On the other one I toss on some old carpet for a scratch prevention layer when working on heavy metal parts.
pics
M
   / Need help putting formica on my workbench #19
on the Formica, over saw it about 1/2" using a fine toothed blade, clean up the ply wood, apply a good grade of contact cement, use some dowels to hold it up so one can position it, remove dowel on one edge and start to position it, and move along, and trim up with the 15 degree Formica bit, a hand file an take off any sharp edges,
do the front edge first, and trim with a square Formica bit, make sure he front edge is square, fill any voids with some good wood putty (like Durmas rock hard putty), sand smooth
that is how I would do it,
but IMO a steel sheet broke would be best,
I put melamine on a larger work surface on a rolling table. Since it was supposed to be redone frequently I simply contact glued it down with a spray 3M product. That way it would stay stuck yet I could still peel it up when I needed to. It's been on for a few years now and still looks excellent.
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
