Need help TZ25 3 oint troubles...again!!!
   / Need help TZ25 3 oint troubles...again!!!
if you tie thge lift handle 'up' does it effect the leak down any? No it does not. I've tried that, moving my remote valve.... maybe the "check valve" would be worth a try. Jinman, when you say leaking.... you do mean internal leak? Maybe I will call the dealer and see how much these valves are. Start with the check valve, and see what happens??? Spring WILL get here sooner or later, and I want to "play" with my tiller. I appreciate everyone's help. Thank you!
   / Need help TZ25 3 oint troubles...again!!! #22
maybee trash in the check valve?
soundguy
   / Need help TZ25 3 oint troubles...again!!! #23
soundguy
Like a little metal shaving from the machining of the parts or even some thread sealing compound that dislodged and got caught in the check valve. Not unusual. It should be easy to fix instead of needing replacement. just be careful of the order the parts are in when taking it apart and putting it back together. Watch out for the spring loaded ball!
   / Need help TZ25 3 oint troubles...again!!! #24
...maybe the "check valve" would be worth a try. Jinman, when you say leaking.... you do mean internal leak? Maybe I will call the dealer and see how much these valves are. Start with the check valve, and see what happens??? Spring WILL get here sooner or later, and I want to "play" with my tiller. I appreciate everyone's help. Thank you!
The site mentioned by DSteiner looks like a dealer only site. You have to register and get a userid to use it.
A User Name and Password is required to access this site. To request a User Name and Password, please submit the New Dealership Signup Form, accessed from the menu on the left.
The same information is available at Messicks.com, click here. The following was copied directly (except the red :) ) from their site.
VALVE, CHECK
SBA340980150 <----- Different from the one mentioned earlier
$477.57
Avail in 3-5 business days
VALVE, SAFETY
SBA340980140
$546.03
$477.57????? $546.03?????? HOLY SMOKE!:confused2: Well, it looks like I will be looking at them first. Later this week, when the threat of snow is gone, I will take these out and make sure they are clean, and go from there. Thanks guys! If you ever need advice on an old Oliver, just ask... LOL ...John.
   / Need help TZ25 3 oint troubles...again!!! #26
Oh my!:eek: I looked directly at New Holland's site and didn't see the prices. Holy smokes! That whole valve is over $2600. OUCH! Double OUCH! You sure wouldn't want to Easter egg that problem.:confused2: I am truly stunned by those prices.
I hope Drewtrac can find something more. He seemed to think that new tolerances have been established in the part and it has much slower leakage.
   / Need help TZ25 3 oint troubles...again!!! #27
I only see two parts of the check valve that could have a problem:
1. The ring shaped seat under the ball could have a nick or groove.
2. The spring above the ball could be broken or bent (not likely).
More likely something is stuck in it.
The pressure relief valve should be similar.
What are the chances you can get the individual inside parts?
$2600!!!!!
I think I would look at retrofitting something from another tractor before I ever plunked down that cash.
   / Need help TZ25 3 oint troubles...again!!! #28
At this point.. pull her apart and hope for a piece of debris in there!!
post back and let us know what you find!
worst case.. try to find a working salvage valve...
soundguy
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 Nissan Frontier (A53422)
2017 Nissan...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
Freightliner Tender Truck (A53473)
Freightliner...
