CliffordK
- Joined
- Mar 8, 2013
- Messages
- 2,369
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
Ok, here's a simplified wiring diagram:
TESTING SUBMERSIBLE PUMP CONTROL BOX
Black & Yellow are your main 220V leads.
Red is to the start capacitor.
Green is Ground.
With 220V, you don't really have a "neutral".
You would wire the pressure control switch BEFORE the motor controller box.
Anyway, a Motor Controller Box should be about $30 at your favorite building supply store for a 1 or 1.5HP pump or so. I certainly would just go get the proper equipment. Another $20 or so for the pressure switch.
What are you pumping the water to? Read about dead-heading pumps.
I really think the right pump for the project is a shallow well pump, and not a $500 submersible pump.
HF has a 1HP shallow well pump plus pressure switch plus small tank for $120.
Also, 1" Clear Water Gasoline Powered Pump for about $145, as well as 2" and 3" gas powered pumps.
Green is Ground.
