Need Ideas
   / Need Ideas
Thanks for all the great ideas I will have to do some studying now and find what is best that I can afford!! :thumbsup:
   / Need Ideas #12
...Any other suggestions looking for low dollar fixes not wanting to asphalt or pave at this time..
Low Dollar = Dump gravel on top of the grass. Spray roundup later.
If you start with a larger rock like road base and gradually over the years add smaller rock as the bigger stuff gets packed down, you'll end up with a good packed driveway. In the mean time your rocks may be a little loose to begin with, but you won't have the mud.
   / Need Ideas #13
For 80 feet, I'd start with a single load, which should be about 25 to 27 tons of road base gravel. That will give you a good, solid four plus inches of rock.
What you want to do is send the water off to the sides and away from your road as fast as possible. Digging out the top soil is only needed if you have a layer of organic material that you want to remove. Such as top soil. If it's sand or clay, then there is no reason to remove it.
When road base is 4 inches thick, or thicker, it will lock together when compacted and becomes a VERY GOOD road. It will hold water and it will shed water. It's up to you to get the water away from the road and not let it get under the rock. If it does, it will wash out under the rock and you will wear thinn real fast.
NEVER drag a box blade over a compacted gravel road. All you do is break up the rock, make it thinner and ensure a faster failure rate.
How much rock you buy depends on how high you need to build up your drive to get it to crown and send off the water.
If you buy any sort of paver, you still have to give it a solid base underneith. Lots of places pour concrete under pavers to give it a solid base. You don't do pavers to save money, you do them because you like the look enough to spend extra money to have them.
Good luck,
Eddie
   / Need Ideas
Great ideas I was planning to skim the sod off and bring in a load of bigger gravel for this year and maybe hit with some smaller gravel next spring after it settles in...The soil isn't all sand but it does have alot of sand in it!! :thumbsup:
   / Need Ideas #15
I second the idea of geotextile fabric as underlayment. It has done a fantastic job keeping the gravel up on top in a boggy area my drive goes through. Try Craiglist to look for sections left over from bigger projects.
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
20ft Shipping Container (A57453)
20ft Shipping...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
More info coming soon! (A55851)
More info coming...
2014 Aerway Aerator (A55973)
2014 Aerway...
