Need Info on A.C. 5030
   / Need Info on A.C. 5030 #1
Gunfighter
West Michigan
JD 790, Steiner 230, IH 340U, Farmall Super C, Farmall C, IH Cub Cadet, Wheel Horse 8.75
Would like some info on a A.C. 5030, engine HP, PTO HP, engine displacement
and who built these tractor for AC...
I know there is a web site where I can type in make an model an it'll give a
run down on the tractor but due to a hard drive replacement I no longer have
the URL...
Any help would be appreciated.
Thanks in advance
Richard
West Michigan.
   / Need Info on A.C. 5030 #2
I don't remember who actually made them, but they were sold under AC, Case, hinimoto and a few other brands. I have a owners manual at my farm that I think covers the 5020 and 5030. I'm going by memory but I think the 5030 is 30 HP, 25 pto. I have the 5020, which is 25/20. I'll be going there sunday if you have other specific questions. I do know that parts are getting harder to get, but on the good side, in almost 15 years, all I've done is replace the water pump.
Sounds like the AC 5030 is the same HP as my J.D. 790, this is good.
This summer I ran into a problem where I had to many Implements an not
enough 3 point hitchs to put them on...
A friend of mine ran across a AC for $3900 dollar with 1500 hr that doesn't
look to badly beat up an is seemed to run OK.. Unfortunately it's only 2 WD
with turf tires...
Don't know if $39 hundred is high/low or about right. Compared to JD & NH
used tractor prices it sounds on the low side but then I don't know how sever
the parts problem can be...
Is that 2, 3 or 4 cyl engine and is the trans 6, 8 or 9 speed... live or trans PTO?
I thank you much for the reply and would appreciate any other info you can
pass on... It's about a hundred mile drive to where the tractor is located.
Thanks Again...
Richard
West Michigan...
   / Need Info on A.C. 5030 #4
The 5030 is a 2cyl, live pto, 12fwd/3rev speed tranny. It's 4/1sp with l/m/h ranges. Personally, I would think 3900 would be a little high. Remember the parts statement in my previous post. That being said, I DO like mine. I'll look up displacement this week, but I remember it doesn't give lift capacities.
   / Need Info on A.C. 5030 #5
I believe Toyosha built the AC 5020 and 5030. They also built for Massey Ferguson and Simplicity for a few years.
Regards, Mark
   / Need Info on A.C. 5030 #6
Tractor Details for ALLIS CHALMERS 5030 .
Tractor Details On File
Years Made: 1979-1985
Horsepower - PTO: 26.42
Horsepower - Engine:
Horsepower - Drawbar: 22.4
Horsepower - Range: 26
Engine - Make: TOYOSHA
Engine - Fuel: DIESEL
Engine - Cyl(s) - CID: 2/90.1
Transmission - Standard: SG
Optional:
Forward / Reverse Standard: 8/2
Forward / Reverse Optional:
MFWD - Standard / Optional:
Tires Standard - Front: 5.00-15
Tires Standard - Rear: 12.4-24
Wheelbase - Inches:
PTO Type: LIVE
3pt Hitch Cat I: True
3pt Hitch Cat II: False
3pt Hitch Cat III: False
Hitch Lift:
Hydraulics - Type: OPEN
Hydraulics - Cap:
Hydraulics - Flow: 5.44
Hydraulics - Standard Outlets: 1
Cooling Capacity: 5.3
Fuel Tank Capacity: 7
Cab Standard:
Weight: 2685
New Price: $9,230.00
Serial Numbers On File
Serial: 2005 | Year: 1979 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 2255 | Year: 1980 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 3520 | Year: 1982 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 4066 | Year: 1983 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 4214 | Year: 1984 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 4359 | Year: 1985 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
Serial: 2976 | Year: 1981 | Plate Location: ON PLATE, REAR OF CONSOLE, UNDER STEERING WHEEL
I want to thank all you fellows for the info. Think most of my question
have been answered. If we don't get to much snow this weekend, I'll
go look at the tractor early next week...
Thanks again
Richard
West Michigan
   / Need Info on A.C. 5030 #8
That's right, built by Toyosha/Hinomoto. The AC 5030 is the same tractor as the Simplicity 9528. (AC owned Simplicity for many years).
Informational Lot - Shipping (A56436)
Informational Lot...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
skeleton / rock bucket (A56857)
skeleton / rock...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
