NEED info please...
   / NEED info please...
Well thanks for all the info gents I have managed to fix the starting for now.. I removed the solenoid and disassembled it. The Battery and Starter contacts were not making a connection. Some cleaning and sanding of the terminals and back in business. 31 Degrees here and fired right up with the help of the glow plugs (a count to 10). Next I am going to post about my gauges not working after I look at the forum to see if there's any info already there to keep from reposting..
Thanks again
Dan
   / NEED info please... #12
Sounds like the guys are getting you ironed out. I see you are a Indiana boy also and have "fly" in your name.
I am in the Anderson/Muncie area and a corporate pilot with a Jinma. Do you fly or maybe a controller? Also where are you located?
Sorry to get off topic but just wanted to say hi. You are going to get good advise here.
Chris
A controller at Indy Center live between Martinsville and Bloomington. I have 13.5 acres to care for..
   / NEED info please... #14
Very cool. I fly N964C Sabre 65 out of Muncie.
Chris
   / NEED info please... #15
YD380 is chinese yangdong engine, 3 cylinder and Bore is 80mm, so it called YD380 engine, it is a 20HP engine.
   / NEED info please... #16
glad you solved the issue, please keep us up to date on the others.
2012 MACK CXU613 (A53843)
2012 MACK CXU613...
CABINET (A53843)
CABINET (A53843)
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
2005 FOREST RIVER WORK AND PLAY (A53843)
2005 FOREST RIVER...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
