Snow Blade need new snowplow
   / need new snowplow #1
gravelman
Platinum Member
NH
Kubota 2650
gravelman here..i have a Kubota 2650 looking for a quick attach hydraulic angle snowplow...i believe it could handle up to 7 footer.... any brands suggested?? i like full trip too
   / need new snowplow #2
Your Kubota dealer should be able to help $$$$'s try Fisher & Boss & Curtis dealers.
   / need new snowplow
ok, good leads...thanks much
   / need new snowplow
i do not have a welder but know someone that does... i do have third valve plumbed to the front... thanks
   / need new snowplow #6
Perfect, plows have become stupid expensive and I and a few others here have some P.U. plow build threads if your interested in that route. I have the measurements/angles to build the ssqa.
As there's snow on the ground now, you may not have the time. I bought a "Snow Wolf" brand plow and it's been very tough. The 10,000 pound skid loader it's used on has no mercy on it and after 10-12 years, it's doing just fine. Skid Steer Plows, Skid Steer Snow Tires, Snow Pushers | SnowWolf Plows They have a dealer locator and iirc, Milton Cat is one.
   / need new snowplow #7
I Have an HLA Plow, very heavy, great quality. If you use hyd to angle plow, ensure you have a cross-over relief system.
HLA Snow | 2 SnowBlade
   / need new snowplow #9
Purchased mine from Michigan Iron & equipment Morrice MI..Very stout set up..
   / need new snowplow #10
Or just pull the loader off, drop 2 brackets off the tractor frame and add a raise/loader cylinder. Use the loader controls to do all the functions. You don't need pitch control if you set it up right, you need raise/lower and you very much need angle left & right.
Also, connecting and reconnecting couplers may not be practical if one gets pressurized. You will have to bleed it off to connect it.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
TMA (A49461)
TMA (A49461)
