Need PTO expertise-mount blower on front
/ Need PTO expertise-mount blower on front #1
smiley
Platinum Member
Upstate NY
I'm in the process of installing an 8 ft snowblower on the front of my Massey Ferguson 399 and have run in to something I don't have much experience with, short PTO shafts. If you can see it in the photo, the output shaft of the reverser on the front of the tractor, is about 7 inches higher than the input shaft of the blower. The shaft will only be about 18 inches long including the u joints, so will have a pretty good angle on it when the blower is working in the lowest position. Can anyone with knowledge on this subject tell me if there are going to be any problems with running the shaft at this sharp of angle. If absolutely necessary, I can move the reverser back and lay it on it's side to lengthen the shaft and get it more in line with the blower input shaft, but that complicates matters greatly.
Thanks for any info.
Smiley
/ Need PTO expertise-mount blower on front #3
So is the reverser running off the rear PTO? Can the reverser be lowered to get it more in line? How about mounting a shaft in pillow block bearings above the snowblower input shaft that would connect to the PTO and chain driving down to the blower? That's the setup my Kubota front mount has only it is dropping it down instead of up. If you google driveline angles you can probably find what the maximum running angles are.
Kim
/ Need PTO expertise-mount blower on front #4
If you look at most factory front mount blowers that run off a 2k RPM mid PTO, they have a couple of sprokets and a chain to lower the 2k down to ...say...540ish. You could do a simular thing and run your PTO shaft straight out, then drive the lower blower shaft via chain. You want to keep the PTO shaft as straight as possible, especially a short one. Doesn't take much up/down movement on the implement to increase the angles. Most PTO angles over 15 degrees shorten the life span of the U-joints under load drastically.
/ Need PTO expertise-mount blower on front #5
If I'm looking at that picture right, that is too extreme for even a double cardan.
The morer I study this, the confuseder I gits. From what I'm finding , a great deal depends on the design of the joint itself, from a minimum of 15 degrees to a maximum of 45. Apparently good design generaly calls for as little as possible, preferably less than 30. Here's a site that covers it pretty well.
Couplings and Universal Joints - Types of flexible couplings
I will be right in the 30 range the way it's presently set up with the blower down in the working position, to about 0 degrees when raised. I'll study it a little more before deciding. If necessary, the reverser can be moved to the rear which is what it was designed for. The reason I'd prefer to mount it in front is I could leave it mounted in the summer and just remove the chain from the rear PTO drive, where if it's in back, I'd have to remove the whole unit to use any other PTO equipment.
Kim
Yes it drives from the rear PTO via a shaft to the front. I will consider mounting a jackshaft on the blower itself. That would eliminate the angle problem. Also considering moving the blower further forward to lessen the angle.
/ Need PTO expertise-mount blower on front #7
Another thing to consider is an angle between the drive and driven shafts. Ideally they should be in line or parallel. If they are not parallel then the driven shaft will have variable angular speed in each revolution. In other words it will go two quadrants faster and two quadrants slower than the drive shaft. If the driven equipment has large mass (large inertia) it will put stress on the drive mechanism. In such case you shouldn't use cardan but constant velocity (homokinetic) joints. CV joints can handle larger angle than cardan joints.
I figured out what to do with this project. By moving the blower forward about 7 inches, it lessens the angle to about the 15 degrees. That will put more strain on the snowplow lift that raises it, but if necessary, just behind the reverser you see in the photo, is a 50 ton winch. I think that will raise the blower OK.
/ Need PTO expertise-mount blower on front #9
How about making a frame to hold the blower but with a joint so it can be lifted, and use an electric 12 volt winch to raise it. I saw a front blade like that recently on a Ferguson TO30.
For powering it someone makes a pto gearbox to send the power forward, use an old rear wheel drive driveshaft with adapters to fit it on to the output and input shafts, and with u-joints at each end.
My pack rat bro-inlaw has 5 shafts in his shed, all long enough strong enough, maybe he'd give me one.
An alternator with lots of amp capacity would be needed to run the winch.
Here's an available kit, maybe they would adapt it to different machines or sell just the gearbox and shaft.
Lorenz Front Mount Kits
----------I already have a 50 ton hyd winch on the front but am not using that. Am using an electric/hydraulic snowplow lift, as it gives me angle capability when I'm using the plow I mounted 3 years ago.----------
For powering it someone makes a pto gearbox to send the power forward, use an old rear wheel drive driveshaft with adapters to fit it on to the output and input shafts, and with u-joints at each end. My pack rat bro-inlaw has 5 shafts in his shed, all long enough strong enough, maybe he'd give me one.
------------I'm using a chain drive from the pto to a 1" shaft running to a pillow block and u joint in the middle, to a reverser mounted on the front bumper and skid plate under the front axle.----------------
-----------That's a nice rig but I'd hate to see the price. I think a hydraulic conversion might be cheaper. Through scrounging, I'll wind up with about $150 in my conversion. Most of that ($100) is in a reverser I bought from another member Piloon, while visiting my inlaws in Canada. If I hadn't found this reverser, I was going to use one off a field chopper or a Ford Ranger front differential, as a reverser.
I am waiting on a smaller drive sprocket (found sprockets online at about 1/3 the price of TSC) and will be finished this week hopefully. I'll post a full write up with photo's as soon as it's done.
Smiley
/ Need PTO expertise-mount blower on front #11
I may become entangled in a front blower project.
Can you give me the manufacturer name of the rear-to-front assembly ?
I am GUESSING that these are a common part that different manufacturers buy, don't make.
I'll see if I can find the name on it but it may be where I can't see it now. It was commercially built in Canada but would be very simple to build. If you look at the photo in my first post, you can see that it's just 2 pieces of channel about 3 ft long, spaced apart and welded to the vertical frame in front that holds the sprockets. A shaft from the pto runs through the channel and has a sprocket on the end, that drives the chain that runs up top to an idler sprocket, then across the top to another idler sprocket, then down around the back side of the front drive sprocket and then back to the main pto drive sprocket. This one was originally built to be mounted on the rear of the tractor but worked better for my application by mounting it in the front.
/ Need PTO expertise-mount blower on front #13
That reverser was built by Bervac which is now Rad technologies in Drummondville Que.
I don't believe they are being produced any more.
(I was the person that sold the unit to Smiley!, so I know! LOL)
Hi Smiley, you got all our snow this winter, we are skiing on grass, LOL.
Hi Piloon,
Actually we have only about a foot on the ground. Most of it went south and east of us but winter isn't over. My Sister in law in Laval had about 1 1/2 ft when we were up there about a month ago.
The only time I had the tractor out, I let about a foot build up in the driveway and it worked well until I decided to crowd it a little harder. Shifted up a gear and went into the 18" bank the plow had kicked up and sheared the 1/4 " soft bolt I used as a shear pin. Replaced that with a grade 5 but haven't had enough snow to bother to take it out. I'll see if that works and if it shears to soon, probably step up to 5/16.
Smiley
Kubota M125X (A60462)
International 9200 (A61307)
International 9200...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
1999 Ford F-140 4x4 Pickup Truck (A59230)
1999 Ford F-140...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A59904)
2003 VOLVO VNL...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
