I'm going to throw out the weight you would be hauling at 8000 to 9000 lbs. That probably means a 14k trailer. If I was hauling that a lot or long distances, I'd want a gooseneck. If not a bumper pull would probably be fine. I'd count on the load your hauling plus the trailer being at least 11,000 lbs and maybe more like 12,000 lbs. I haven't looked up the actual capacity of your truck, but I bet thats more than you should be pulling. That said, a good hitch, a weight distributing hitch with sway control, you would be safer than some of the stuff you see going down the road.
