You mentioned a HOA so I assume you're in a built up area. Where is this proposed drainage to go? Onto a neighbor's property? Street? Storm drain?
Seems like diverting the water before it gets to your house would be the easiest, and making sure you have a good raingutter system that also flows the runoff far enough down hill.
A 9' deep trench the width of even a narrow bucket is one **** of a lot of dirt, better put an ad on craigslist right now for free dirt.
Good luck, I hope the purchase price reflected the needed repairs. Joe H
Thank you for all of the insight and expertise. I will review the links that have been submitted.
I have posted the last engineers report here, from 2008, and you'll see while he does NOT recommend piers, yes watering, and the last sheet explains why, he says nothing about french draining:
http://www.picklebush.com/Pranther_Engineering.pdf
To answer some of the great questions in this thread:
If the piling is not to level the house, perhaps the piles are needed because once you install the french drain, the clay under the house will dry out and shrink and so the piles will stop the low side from subsiding?
>>The thought is from the engineers in the area, is the concern if the water/expansive clay is removed, that the house will level back down to something, maybe not perfect, much more closer to a level original build.
If the high side has no piles, is he hoping the house will level out and that if he lets the high side settle but not the low side, the house will reach an even keel? What does your engineer say he is trying to achieve?
Yes, even keel and then consider piles if needed. What they want to achieve is obviously the heaving causing the house to be out of level... I guess I'm not really understanding the question, sorry.
>> A purpose statement from him would remove any guesswork. The second engineer report attached in this post has a purpose... I think?
I'd still consider a drain on your uphill boundary to get rid of the surface water coming from uphill. This will reduce the amount of water getting to your foundations but also make your yard drier and so more usable.
>> I totally agree, but oddly, if surface water typically travels in the top 24 inches of ground, then why is the neighbor going 9feet to prevent any surface water. The neighbor is to MY NORTH, where the maximum swelling is.
A surface drain or swale on your boundary will be much cheaper and easier to do than a french drain around the house. As I understand it, it should also get rid of the water source which is the cause of much of your problem although, of course, it will do nothing to help level the house.
>> Maybe, the water source, while not really known exactly, is to the "EAST, SOUTH EAST, the high point of the hill... but my house isn't suffering on on the South East/South side... that side is actually low!
Has it been explained to you that to undertake the piling you're going to have to raise the house?
>> Yes. We have bids from 15K to 50K to raise the house. Interior damage is not in those estimates (pipes, sheet rock, windows, etc)
How else do you get the piles under the foundations and those within the body of the house?
>> They drill a man size hole through the foundation and f'up the floors.... not something we really want to do.
1. Is the heaving any worse than in 2005?
>> Looking at the 2008 report, I would suspect yes. Our cracks on that side of the house continue to expand and we're seeing new movement/damage in other areas.
I hope the 2nd engineer report gives some good information. I would of hired the original firm, but they never returned my phone calls. Both of the reports cost around $400.
I think my next steps:
1. Get french drain quotes for a "Horse Shoe" shallow (3 to 4 feet max) around the pool backside (see image) . This is the PURPLE.
2. Consider a "curtain drain" next to the foundation but only 5 feet deep? This is an uneducated guess.
Notes: When the neighbor to the NORTH put in a sump pump on the alley back side of the house (east), it didn't do any good, because the water flow is from the EAST/SOUTHEAST. However, the south side of MY house has no movement UP, only down.
The ORANGE 1 foot deep french drain between our properties has little to NO effect on stopping water to the neighbors house.
I frequently still have a puddle of water sitting between our houses, so I am not sure it is really doing anything, might be clogged.
THE LIGHT GREEN is my house PROPERTY LINE and the circular area over the house is the area that is HEAVING EXTREMELY.
I think with the image I presented, the 2 engineering documents, and some good insight from you folks, I can at least start phase 1, and that would be the horse shoe drain, approximately 4 feet deep. It might not get the HEAVING to stop on the NORTH side of the house, but it should cut down on the amount of water getting to the house.
Thoughts?
