Need some help- 5410 won't start
   / Need some help- 5410 won't start #1
mstovall
Hi Guys,
I own a farm in Tennesee and have a 5410 with about 700 hours. I went to start it after having shut it down for a few minutes and the starter engaged for a split second and that was it. nothing afterwards; not even a click from the starter solonoid. The battery checks out fine. Since then I have checked out the ignition switch, starter relay, and the other relays and they are all fine. The diode pack does not check (continuity) as described in the service manual. Question- can the diode pack keep the starter from engaging? I thought that the diode pack only effected the fuel shutoff switch.
Let me know what you think,
Thanks,
Michael
   / Need some help- 5410 won't start #2
Well, I have a 5520 and have the same problem frequently. Mine is caused by the "safety" switch under the seat. I bounce on the seat a few times and off we go again. I figure just dampness.
Around here there are a lot of those tractors and the seat thing seems to be a common problem. These are bulletproof tractors so not much goes wrong.
I would be surprosed if anything more than that. Keep us updated.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Ford Fusion (A59814)
2017 Ford Fusion...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
