Need some help / advice with pintle hitch trailer for tractor
   / Need some help / advice with pintle hitch trailer for tractor #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I just purchased a military trailer and plan to use it behind my tractor for such things as firewood, fence posts and wire, brush, etc. It has a Pintle type hitch. I want to be able to hook to my tractor via 3 pt rather than the belly bar so that I can raise and lower the trailer tongue to my desired height. Does anyone have any pics of a pintle type hitch on a 3 pt. adapter? thanks
   / Need some help / advice with pintle hitch trailer for tractor #2
My suggestion is a 3ph to 2inch receiver adapter. Like one similar to the one on the bottom of the TractorByNet home page and the hitch at Northern Tool.
Hope this helps
DanK
P.S. Where bouts you in northeast TX?
   / Need some help / advice with pintle hitch trailer for tractor #3
No pictures of mine, but all you need is one of these:
and one of these:
images
or these:
Dan, in De Kalb, near Texarkana. Monte, who makes those? I really want American Made if at all possible. thanks guys
   / Need some help / advice with pintle hitch trailer for tractor #5
Here is a couple of pics of the 3 pt trailer mover I built. I would get a pintle hitch with a 2" ball that would fit in a receiver hitch so you can move pintle hitch trailers and trailers with a 2" coupler. I have seen them at Harbor Freight and Tractor Supply. Not sure if they are made in the USA.
Pintle Hook with 2" Ball
   / Need some help / advice with pintle hitch trailer for tractor #6
pharm vet, take a look at "build it yourself" winch calculations. Pg 3. I built a frame for using the 2inch reciever system. A simple fix for what you need. These have winches, but they don't have to be there if not needed. With the frame you can hang a few chainhooks on also.
   / Need some help / advice with pintle hitch trailer for tractor #7
I plan to add a 2" receiver tube to the top of my box-blade, and then use the pintle hitch from my truck.
   / Need some help / advice with pintle hitch trailer for tractor #8
If you are any good with a welder or know someone who is, you can make one pretty easily. I went to the junk yard and bought a reese style hitch off a truck for $10 and made one similar to those talked about above. The pintle hitch I bought used for $20. So total, I had about $30 plus my time.
   / Need some help / advice with pintle hitch trailer for tractor #9
Just a caution about using the 3 point hitch as a trailer hitch. There is no down force on the 3 point. If the trailer exerts an up force, the hitch will just lift. I think some people on here have attached a chain from the draw bar to get around this issue.
   / Need some help / advice with pintle hitch trailer for tractor #10
I load/design my trailers to be tonque heavy. I also raise my 3pth to unload the trailers. To hook up I just lower 3pth, back under ball then raise hitch and drive away, most times not even latching the hitch. Actually I mostly leave a 1 7/8 ball in my reciever no matter what size hitch is on the trailer. (maybe I will match the hitch to ball on a heavy load of logs, sand, etc)
If I had to get on and off to unhook a chain every time my old knees would give out in short order....
Kivel 48in Forks and Frame Skid Steer Attachment (A44571)
Kivel 48in Forks...
Toro ZMaster 7500 Series 72074 72in Zero Turn Mower (A44572)
Toro ZMaster 7500...
MK Diamond Wet Tile Saw (A45336)
MK Diamond Wet...
1987 Mack RW613 Truck, VIN # 1M2AY04Y3HM003150 (A44391)
1987 Mack RW613...
5x8 Southern Sales Dump Trailer (A44391)
5x8 Southern Sales...
CAT IT28 Wheel Loader Pallet Forks (A44391)
CAT IT28 Wheel...
