Need some help with a PTO shaft cover
   / Need some help with a PTO shaft cover #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I bought a King Kutter tiller and the cover that goes over the PTO shaft on the tiller end is off. I have the white plastic clip that goes over the shaft that holds the cover on, but I need to take the cover apart. You can see that it comes apart into 2 pieces, but I cannot figure out how to do it. If you look at the second picture, you can see towards the bottom of the cover that there is a hole with a black plastic thing in there. I can put a screw driver in it and turn it but am not sure if that has anything to do with splitting the two. Any help please?
I finally figured it out. The two pieces on the end do not come off, they have to rotate. This link helped me out. I figured I would post it just in case someone else has this same issue.
Link
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
30" Backhoe Bucket (A50775)
30" Backhoe Bucket...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
2019 Kubota R530 (A53314)
2019 Kubota R530...
S/N: 2136118 (A55853)
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
