Need some measurements on Ramps for trailer
   / Need some measurements on Ramps for trailer #11
   / Need some measurements on Ramps for trailer #12
If you use jacks on the rear of the trailer, get "drop leg" jacks so you are not standing around cranking. For this function, a crank type of jack is not needed.
As for putting stands on the ramps, you probably need to drive the tractor on and off a couple times to measure and eyeball. The stands need to support the rear, but also allow you to swing up the ramps afterwards, even if the trailer has squatted. You need to account for that otherwise you might not be able to swing the ramps up again. For sure, the stands can't be touching the ground with an empty trailer or they will definitely not allow the ramps to swing up when you have a load.
None of this is complicated, but it's not something we can design over the internet -- needs to be customized to the trailer and loads.
Or just get some drop leg jacks welded on and be done with it. They will have so many pin positions that you can always adjust the jack height for every scenario.
   / Need some measurements on Ramps for trailer #13
I just put blocks of wood under the back two corners of the trailer leaving 3 to 4 inches of clearance between the blocks and the trailer. If you end up without enough clearance you can just drive the tractor forward until the trailer is off the blocks, then remove blocks, then move the tractor back until your tongue weight is right. With that said though, I always put the blocks cross wise to the trailer in case I need to pull the trailer off the blocks.
I never cared for the jacks, just something else to get torn up or be in the way.
   / Need some measurements on Ramps for trailer #14
my cure for heavy ramps!
Broke Farmer John, Thanks for the info on the other page; I followed you over.
What Is your deck height at the end of your dove tail when the trailer is level? How long are those ramps? I am asking because I have a lowboy but no dove tail and am trying to get a feel for how long to extend my 5' ramps.
I agree with you on investing in those ramps. I sure would like to have them but I don't think I want to pay for them
My ramps are 4 1/2 foot long, I don’t have an accurate measurement from the deck to the ground. On un level ground it’s 25-27inches, I would guess it’s around 25 inches on pavement.
I went to deliver that Super C with my buddies truck because mines down. Hour and 20 there, unload and hour and 20 home turned into 9 hours and my trailer at my buddies place and his truck in the shop.
I think drivers side caliper stuck on, it was pulling left, I pulled over and smoke was rolling from behind the wheel, I poured water on the tire, CV boot and all the rubber in the area to make sure nothing was smoldering.
By the time I had someone get the trailer, deliver the tractor, load my buddies truck on my trailer and take it to his place it was a good 9 hours.
I should stop doing things for people lol. I was the one that pointed the tractor out and after my second cousin bought it said I could deliver it, I wouldn’t have lost a day if I didn’t.
Second cousin gave $1300 for that super C and bush hog, I threw a charger on the battery, it fired right up, the generator isn’t charging the battery, that’s all that’s wrong with it. It’s all painted up and looks good.
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2024 Chevrolet Tahoe SUV (A56859)
2024 Chevrolet...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2007 John Deere 6215 (A57148)
2007 John Deere...
