Need some tech advice on 23 HP Kubota. Please...
   / Need some tech advice on 23 HP Kubota. Please... #11
Sean - You might want to buy two spares for future problems, while you are at the dealer. I don't think they are very expensive and may save another trip, or having to wait for the dealer to open.
Along with 2 SPARE fuel filters you may want to have a hydraulic and air filter on the shelf as well as a jug of super udt to avoid long term outages!:D
   / Need some tech advice on 23 HP Kubota. Please... #12
I have engine oil , super udt , oil filters and tranny filters on hand ; but I never thought of the air and fuel filters.
   / Need some tech advice on 23 HP Kubota. Please... #13
Ill tell you another.My 23 was down for a week waiting for a lower radiator hose.Ikeep a spare now[8dollars] Ikeep a spare alternator belt,2 fuel filters,oil and hydraulic filter.Im thinking of a spare hose for my fel.They all look about the same,be nice to have a spare.
ALAN
   / Need some tech advice on 23 HP Kubota. Please... #14
changing the filters and adding power service (white bottle, not, repeat not, gray) should do it ...sparing the filters is a must ...and, while you are looking for power service in the white bottle, look for the orange '"diesel 911" from same manufacturer ...keep a bottle on hand.
I'm not familiar with your tractor, but if one of the filters is at the lowest point in the fuel system, that is where water would show up if there is any ...is there a glass bowl to inspect? or, a drain cock ...if the latter, drain a cupful, or so, into a clear container and look for a water bubble in the botttom ...if you find one, you might regularly drain a little fuel, there ...and consider reviewing where you got the fuel, when, and how you put it in the tank. If there is water there, I would drain the tank and refill with known good fuel or "polish" the fuel you took out.
A trick I have found is that if you are pumping or siphoning from a fuel can into your tank, cut the inlet/pickup tube of the pump/siphon on a bias so that it can't suck up the dregs ...which is where water would be if there were some in the fuel.
And, of course, now is the time for "winterized" diesel fuel or #1 (straight, or you can make a winter blend, yourself) ...As others have mentioned in the other threads, kerosene is an equivalent blending fuel, but I would be doubly careful about it's quality.
   / Need some tech advice on 23 HP Kubota. Please... #15
I angled mine (inlet/pickup tube of the pump/siphon ) and put an alum. screen on them to keep the junk and dirt from getting into the pump on my fuel storage set up..
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2022 VERMEER RTX250 WALK BEHIND TRENCHER (A53843)
2022 VERMEER...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
