Need something to glue my tennis shoes
   / Need something to glue my tennis shoes
It's kinda funny, but TBN seems to have the answers to almost anything.:D
How true.
Worse, I forgot that fact and jerked around too long with separating shoes before I asked. I think if you live in a rural environment and aren't filthy rich you learn to solve your own problems and have a skill set most city people never develop.
Maybe it's the other way around....the smarter and more creative problem solving types are naturally drawn to the rural areas?
   / Need something to glue my tennis shoes #12
Another vote for shoe goop, it works great, goop also makes glues for other projects like plumbing electrical etc... I believe it's probably the same stuff just different label?????
   / Need something to glue my tennis shoes #13
I just use construction adhesive on mine
   / Need something to glue my tennis shoes #14
FLEXTRA caulking to reattach front soles on wife's walking shoes.
Gobbed it in and weighted it until cured.
4 years now and still good.
   / Need something to glue my tennis shoes #15
Evidently the Shoe Goo works, but I didn't know about that when my favorite knock around Dexters started coming loose around the sole. I did have Gorilla glue and it has worked fine for about a year. Have to be sparing with it though as it expands and pushes out the edge if you use too much.
   / Need something to glue my tennis shoes #16
ive used shoe goo in the past with good results.
also used liquid nails which i thought held better long term.
   / Need something to glue my tennis shoes #17
Amen. The freaky part is sometimes TBN provides the answer before you asked the question! :thumbsup::D
I have used either Shoe Goo or plain old contact cement in the past.
I will have to try the glue on my JD seat that separated from the base. Looks like they used expanding foam to glue it together and I figured I would have to do something similar. :D
Did I mention that sometimes TBN provides the answer before you asked? :D:D:D:D
Later,
Dan
   / Need something to glue my tennis shoes #18
4 years out of a pair of walking shoes? Wow!! Anything special about the way she walks?
Steve
   / Need something to glue my tennis shoes #19
S..point said what i was thinking. The sole delaminated 4 years ago, so at that point they were not new, so how after 4 years has she not worn through the rubber and walking through her foam soles? Maybe his wife really does not walk like were thinking 1 mile 3 times a day but just wears "walking" shoes on the weekend in the summer?
   / Need something to glue my tennis shoes #20
Later,
Dan
On my JD seat which had completely separated from the plastic pan I did one section at a time. I put plenty of goo in the track then used clamps and a scrap piece of 1" x 4". Let it set over night then did another section. It has held for four years.
2020 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50775)
2020 Bobcat T770...
2006 FORD F-750 4X2 DUMP TRUCK (A52706)
2006 FORD F-750...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Mermaid Statue (A53316)
Mermaid Statue...
2018 Ram 1500 Pick Up (A47477)
2018 Ram 1500 Pick...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
