Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,663
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I have a 22 ton (@3000 psi) splitter that opens to over 26". It has an automatic kickout return detent valve. I cut my wood 18". This morning I put a stop on the splitter to kickout the return detent at about 20". It appeared to be working great until I heard a snap after splitting 1/2 cord. The wedge bolt broke and the wedge holes were strectched in the pull back direction. Here is my stop - a 3/8" plate bolted down with 3/8" Grade 8 bolts. I thought I could drill additional holes to set the sop at longer lengths. The original stop was internal to the ram.
Here are the deformed holes. It appears to me that the holes stretched because of my stop and then finally the bolt broke. The wedge side plate material is 3/16" and the bolt was a 1/2" grade 5. The bolt does not see shear in the split direction because the ram end contacts a header in the wedge.
The valve is supposed to release at 1000 psi or about 12,500 lbs. Can I make this work reliably with a 1/2" grade 8 bolt and beefed up wedge? If so how thick do I need to go on the wedges side plates ?? Or should I just scrap the idea and go back to the drawing board ??
Thanks, gg
Thanks, gg
