JD 455, but no 4WD. Are you sure you need 4WD? This really reduces the number of tractors, especially in the GT size range. Also JD x729 or X749 will have 4WD. Though these will be hard to find uses due to their relative newness. Other deeres: 4100, 2305, 2325. Maybe a 750 or 755. The other subcuts from Massey, New Holland etc. would also fit the bill.
OK, posting with a quote is not one of my strong points!
Anyway, Gittyup, you pose a good question. I'm _not_ sure I need 4WD, but here's the thing. The concrete drive I need to pull the 750# boat/combo up is very steep. It accesses the basement shop garage door from the elevation of the house garages, so it drops 8 feet or so in a short distance, and also includes a tight radius turn. I have had to put the 1/2 ton truck in 4WD to come back up this slope. Otherwise, the inside rear wheel loses some traction. However, this may be due to less weight being on this wheel when making the tight turn and the truck frame twisting a little and taking weight off this wheel slightly?
Possibly the more flexible frame and narrow tread width of a subcompact size tractor/large garden tractor would make this a non-issue?
Unfortunately, I may have to resort to just bringing a unit to the house and giving it a "test drive" to get the definitive answer. Was trying to avoid this since it would be a PITA.
I would not have any other use for 4WD and actually prefer the less costly 2-WD. This unit will be used as a lawn mower 98% of the time and I can always use the
L3000 if I need the extra power and 4WD.
I think the JDX729/49 size unit mentioned will be too big/heavy/expensive for what I need here.
Thanks for all the replies so far.
John S
