Oil & Fuel Need tips for 2538 oil change and fuel filter upgrade
   / Need tips for 2538 oil change and fuel filter upgrade #1
karltinsly
Austin, Texas
Mahindra 2538 HST
I'm new to tractors and am coming up on 50 hours on my 2538 HST. I normally pay to have the oil changed in my cars, but have decided to do the tractor service myself, since it's so expensive (well over $300 just for the filters and oil). I have a couple of questions for those who have done this kind of stuff before.
Do I need to keep the waste oil and hydraulic fluid separate for disposal? I plan to use two different 15 gallon drain pans, so it should be easy to keep them separate for this first one, but I wanted to find out if it's necessary, for future reference.
I would like to add an external clear fuel filter, as I've seen in a couple of other threads. Can someone recommend a specific filter, or at least let me know what size the fuel lines are, so I get the right size barbs?
I plan to buy the filters from the dealer, drain pans from amazon, and the fluids at TSC. I've got basic hand tools - are there any other tools you would recommend? Filter wrench? Long funnels?
Thanks for any guidance.
   / Need tips for 2538 oil change and fuel filter upgrade #2
Where I recycle all of my used oil it all goes into the same tank whether it's motor oil, hydraulic oil or heavy gear lube. Get yourself a good filter wrench because Mahindra paints them on at the factor and they can be a real bear to get off. Especially since the location and accessability is not so service friendly. You'll see what I mean when you get to it. BTW I use full synthetic motor oils. It costs a little more but in my estimation it's well worth it. When you get to the hydraulic oil I use the traveler premium stuff from tractor supply. According to the label it's approved for Mahindra. The manual says hydraulic filter at 50 and the fluid at 100 but that doesn't make any sense as the fluid drains out when you remove the filter. DUH! So I just did both of em. At the least you'd make a mess attempting to change the filter with all the oil still in it.
Thanks for the advice! I've ordered what I hope is a good filter wrench. My manual says to change transmission fluid and filter at the same time - they're the same line item - at 50 and then every 500 hours after that.
Wish I had bought the fluid at TSC last month, when it was on sale. I will go with the premium traveler.
Which synthetic is best?
   / Need tips for 2538 oil change and fuel filter upgrade #4
If you plan on changing your engine oil every 100 hours, per recommendation, I've had good luck with Wix oil filters. Get them from Amazon or ebay. Much cheaper than the dealer (at least in my case). I use TS hydraulic fluid too.
One suggestion...the hydraulic fluid is so clear, that it's tough to tell in the viewing glass if you're full, or low on hydraulic fluid. I made a homemade dipstick for the reservoir to make sure I don't mis-read the fluid level. And be sure you put the cap back on the top of the reservoir. I didn't a while ago and it was VERY costly to replace it.
Welcome to the forum, and enjoy your 2538. I love mine. Works like a mule.
   / Need tips for 2538 oil change and fuel filter upgrade #5
I have a 2538 with about 40 hrs on it I bought my filters at oreillys. There both wix filters and they were much cheaper there. I also asked two different Mahindra dealers about changing hydro fluid at 50 hrs and was told they didn't do it until 100 hrs, that it was a waste of money
   / Need tips for 2538 oil change and fuel filter upgrade #6
Make sure you loosen the frame rail (not sure if that is what it is really called). It blocks one of the hydro filters and you can't get it out. Loosen one end and remove the bolt for the other end and you should be able to get it out. I second the comment that the hydro fluid is nearly clear and hard to see through the glass. IIRC it takes like 8.5 gal so put in about 7 and then watch the glass. I entered like 8 and kept adding as I didn't realize it covered the glass :( and had to drain some before i figured it out. Not sure why they couldn't have just put in a dip stick.
   / Need tips for 2538 oil change and fuel filter upgrade #7
Currently I'm using Mobile 1 but any good synthetic of the proper weight and grade should do ya.
   / Need tips for 2538 oil change and fuel filter upgrade #8
This is what you need for those oil filters:
Vise Grip Locking Chain Clamp VG 27ZR | Buy Online - NAPA Auto Parts
Trust me do not buy the cheap big auto store cheapies.......i broke one in one tug of filter.
It took me five seconds or so with this one to loosen it up.
well worth it when you all set up busy working and dirty and oily and those others just won't get it done.
Hope its what you ordered...ha...;)
   / Need tips for 2538 oil change and fuel filter upgrade #9
Here are some links for fuel water separators:
12AS - Diesel Fuel Filter/Water Separator | Hydradyne LLC
Diesel Fuel Filter Assemblies │Donaldson Engine & Vehicle
http://www.baldwinfilter.com/literature/english/6 dahl/Form4005.pdf
IF you plan on adding one of these you will need the specs on fuel flow rate for proper size unit. just thought of it...ok now I'm done..
I used the Baldwin series for my 7.3L ahead of the main fuel filter even when loaded and forgot to replace element still provided good service.
Oh yeah long funnels for reaching in and adding engine oil and Hyd. oils. lots of blue shopping towels and while your ordering don't mind if I spend your money 4 you do yah? :D
This will put a smile on your face when yah gotta grease up the FEL and your cutter: Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine: Automotive
Sounds like your all geared up have fun...;)
   / Need tips for 2538 oil change and fuel filter upgrade #10
Should start looking for a couple 5 gallon oil drain pans on sale. I bought two at my local auto store on sale. Here is a link to one on ebay. Lots of different styles and colors out there. I can't remember how much I paid, but it was way south of $20 a pan.... so a sale is the way to go. Don't know how much your particular common sump capacity is, but both my HST's are around 10 gallons.
11845 Oil Drain Pan, 5 Gallon Capacity 817739:)26 | eBay
I ordered two of these pans: Amazon.com: Hopkins 11838 FloTool 15-Quart Oil Drain: Automotive. $6.67 each as an add-on item on amazon. I ordered a filter wrench and long funnel to qualify.
I am interested in making a dipstick for the transmission. I'm thinking a 1/8 metal rod, dipped into the transmission to get the current level, before draining.
I'll look at getting a chain clamp and locking zerk coupler.
Thanks for all the help!
   / Need tips for 2538 oil change and fuel filter upgrade #12
Fifteen quarts is just short of 4 gallons. You should check your common sump hyd oil capacity... Once you pull the plug you need to have pails available for the full capacity just in case. Please do not ask me how this can turn sour real fast if you are not prepared..... The mental scars take a long time to heal... :)
D'oh! You're right. Thanks for pointing that out. The transmission is 8.5 gallons, the engine is 1.3, and the front axle is 2.2. Don't know why I thought two 15 quart drain pans would hold all that. Back to amazon. . .
   / Need tips for 2538 oil change and fuel filter upgrade #14
I tried several ways to refill my sump. I finally settled on using a bucket pump stuck into the 5 gallon pail of hyd fluid. With the pail set up on a stool to keep it at a comfortable height. I did not take the cover off the pail, and just stuck the pump part down into the opening [ you can make it bigger if the opening is too small. Then stuck the pipe on the end of the hose into the small opening in the fill hole. I tried to just use a funnel/dump it in slowly, but did not turn out too good of an option. Hand pumping in the contents takes a little time, but you get to oggle the arse end of your tractor whilst you work.... helps pass the time. When done, I put the pump into a clear plastic bag and hang it on the wall. Keeps it clean for next time.....
Amazon.com: Powerbuilt 648772 Lever Bucket Pump: Automotive
CASE IH 120A FARMALL TRACTOR (A60430)
CASE IH 120A...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2023 CATERPILLAR 259D3 SKID STEER (A60429)
2023 CATERPILLAR...
