Need tips on drilling upright post holes
   / Need tips on drilling upright post holes #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The Crooked post=crooked fence thread made me wonder why I hadn't asked this before. I pull a line, mark where I want the holes, ease into position, lower the auger, get off, check for perpendicular, make adjustments then bore. On more holes than I want to admit, I still have to straighten the angled hole with a clamshell digger. If there's a better way, someone please tell me what it is.
   / Need tips on drilling upright post holes #2
The angle of the PHD changes as it pulls itself down into the hole
   / Need tips on drilling upright post holes #3
Drill the hole large enough that even if a little crooked, you can still set the post straight. Just backfill / tamp real good
   / Need tips on drilling upright post holes #4
What LD1 says....... I think just about everybody who posts about PHD has that problem on occasion. Helped a friend with his two man, gas driven PHD. What a PITA - he had an awful lot of softball sized rocks - it required a lot of work with the 'ol clam shovel.
T-133 steel posts with my home-made 50# pounder is bad enough.
   / Need tips on drilling upright post holes #5
What I do is to drive the tractor ever so slightly forward for about every foot or so that the auger drills down to keep the auger perpendicular. It really helps to have a second person observing from the side to direct you.
   / Need tips on drilling upright post holes #6
That's a good ratio to keep in mind: "Slightly forward for every foot."
Our Canadian neighbors may want a metric conversion for that. "A pinch forward for every meter"?
:D (sorry)
   / Need tips on drilling upright post holes #7
Hello CobyRupert,
No need to apologize, hiring a bunch of sasquatches with clamshell diggers and buying pizza and beer for the crew would be easier,
I agree a pinch forward for every meter is correct in the scheme of things but a small tree transplanting auger will make post hole digging even easier as it acts like a plumb bob.
I've tried the large hole method and may go back to that if I can't get the hang of creeping forward. Thanks for the ideas and keep 'um comming. I'm hoping someone's found a magic bullet.
   / Need tips on drilling upright post holes #9
Someone once said it takes 6 centimeters to to make a pinch. Does that sound right?
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250208 (A57453)
2000 Volvo VNL...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
2019 CATERPILLAR  XQ35 GENERATOR (A58216)
2019 CATERPILLAR...
UNUSED AGT YSRT14 STAND ON SKID STEER (A58375)
UNUSED AGT YSRT14...
