Need tips on drilling upright post holes
   / Need tips on drilling upright post holes #11
I never drill holes alone. Always have a helper on the ground, help with initial placement, and then gives me the ok to move a bit forward as well. They eyeball it and make sure it goes in straight. ALWAYS for me, the best way to get it done.
   / Need tips on drilling upright post holes #12
As has been said, the PHD radius pushes OUT/AWAY from the tractor and you go down into the hole. This will cause your hole to angle towards the tractor at the bottom.
If you are constantly working to square out the 'away' part of the hole, a little forward movement of the tractor as you drill will fix you up.
But, I second having someone else available to guide you... takes out the guess work.
   / Need tips on drilling upright post holes #13
:thumbsup:
Just what I was referring to in my earlier comment.
stuckmotor, there isn't any "magic bullet".
   / Need tips on drilling upright post holes #14
A larger PHD helps. Mine has a 75 hp gearbox for cat2 tractors. The boom is long enough that it reduces the arc swing as it goes down and on level ground I get a nice post hole, albeit a little egg shaped, but only by an inch or so. With a geared tractor, it makes it nice to not have to constantly move the tractor forward.
   / Need tips on drilling upright post holes #15
set the point a bit 'back' and it will staighten as it augers.
I do 15" holes and backfill/tamp. a bit more work - but straight posts.
Some good suggestions have come in since my last thanks. Thanks again.
Stuck
   / Need tips on drilling upright post holes #17
What LD1 says....... I think just about everybody who posts about PHD has that problem on occasion. Helped a friend with his two man, gas driven PHD. What a PITA - he had an awful lot of softball sized rocks - it required a lot of work with the 'ol clam shovel.
Wanna talk PITA? Try evergreen tree roots! You will wish back to having only rocks.
   / Need tips on drilling upright post holes #18
OK, so here is the 'other' problem. I dig a 10" hole, insert a 5" post, and there is not enough fill dirt. You have to take a bucket full of filler with you. Even worse if you pull the old stump, redrill the hole and put in a new post.
   / Need tips on drilling upright post holes #19
OK, so here is the 'other' problem. I dig a 10" hole, insert a 5" post, and there is not enough fill dirt. You have to take a bucket full of filler with you..........................
Volume wise, physically impossible unless you are leaving something out like rocks when backfilling. If anything, there is fill left over because of the space the post takes up and the original dirt is not compacted like it was before drilling. :confused3:
Then again, perhaps the auger is uplifting some of the soil surrounding the hole forming a mound higher than the original surface of the ground which would require more fill in the hole if not tamped down?
   / Need tips on drilling upright post holes #20
Thanks for splainin' this... I was waiting for his punch line! :laughing:
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A55745)
2007 CHEVROLET...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2024 Frontier FL1061S Hydraulic Flail Mower (A55314)
2024 Frontier...
RAKE ATTACHMENT FOR MINI-EX (A55745)
RAKE ATTACHMENT...
