need to build a dozer style blade for my skid steer
   / need to build a dozer style blade for my skid steer #11
Some interesting reading here:
CHAPTER 6 ROAD CONSTRUCTION TECHNIQUES
Bruce
There are some things shown in those illustrations that we normally wouldn't do on much of a slope. That is casting material to be used as fill onto sloping subgrades. On steep slopes, that fill during rainy season and heavy rains, is liable to loosen and slide right on down the hill. For just a trail it might be ok but anyone building a permanent road should consider bench cuts similar to what they're illustrating as the "full bench and end haul". Instead of hauling suitable fill away as shown though, it can be done as "benches" (steps) with vertical sides. Start at the outside edge of the road about 3 ft below your finished grade and sidecast the material over the side, then step up the 3 ft and sidecast the material into the bench you cut below, compacting it in lifts as you bring it up to road level. This way the fill is sitting on a near level grade instead of a slope and if you're building a super highway, as many benches can be cut as necessary to get any width needed. We sometimes use this method also just to stabilize long steep roadside embankments.
A driveway or logging road could probably be done with just one blade width bench cut.
Wow! That got real long and complicated trying to explain without drawings, something that's in my head from doing it many times so I poked around and found this.
Page 17 of this book shows a sidehill bench cut.
http://www.nra.co.za/content/Blogin/11.pdf
There's also several sites specifically for trail building
A dozer or excavator would be much safer than running a skid steer on slopes like that. If you want a dozer blade for it though, I've seen small junk dozers on craigslist for 12-1400 $ that would give all the parts you need and junk the remains.
I have a 9 ft heavy duty angling snowblade that I use for dirt on my 100 hp 4wd Massey 399, but as others have said it not great at cutting but works good for spreading fill and pushing over waste areas.
   / need to build a dozer style blade for my skid steer #12
Bruce
Nice post Bruce. An educated look into road building/construction using various heavy equipment and multiple technique. Well done. "I have built road for many years in the hills of Northeaster PA. Steep roacky, clay, hardpan stufff and basically follow these techniques illustrated in your attachment. I find that the wider, the better in terms of long term use and erosion control. I build roads now using an excavator and a large tracked skidsteer.
   / need to build a dozer style blade for my skid steer #13
How do you guys usually cut the bench? It seems like you would need an excavator digging so you wouldn't push the whole hill over at once and you could compact in lifts. I just did a job like this with my backhoe on a steep slope and my butt was puckered the whole time.
   / need to build a dozer style blade for my skid steer #14
ROFL. BTDT. I have done a few trails with a small backhoe (Kubota B21). A little nervous especially when moving it on a steep downhill! Then I got a Kubota KX-121-3 mini ex, what a difference! (BTW, the angle blade on the -3 is wonderful for pushing the loose dirt off to the side.)
Before that, I had a contractor with a bulldozer do trails across some steep hillsides. But I've done some with the mini ex (photo above) that I would not have asked a contractor to do. I do remember him slowly sliding sideways on one of the hills he was working on. He didn't try to maneuver until he had a big tree along side him:thumbsup: (I didn't ask him about the adrenaline factor.)
I'm guessing that if you start on a fairly level area with a skid steer and cut a little and pile it down hill to keep a level working platform you might be able to do it with a ss but I'm not ready to commit to that technique, especially with the mini ex available. OTOH, I just did some major renovation and widening with the ss on one of the trails originally done by the dozer. It went very well. My technique was to just the dig the existing trail deeper and push the spoils off to the downhill side. That seems to work pretty well, and better than trying to cut into the uphill side.
Ken
Today was a great test. I started at the bottom of one of my hills working my way up rough cutting for about 300 yards. The hillside wasnt near as bad as what I am preparing for but if I fell off my shelf the skid steer would roll to the bottom without a doubt. I started in a creek bottom where I was sitting fairly flat and got started into the bank. I was actually digging out over my head to begin with but quickly got it down and got up on the hill. I was lucky on this one because I was able to use the conture of the hill. The bank against the hill is 5 feet tall in places. I had to fight the trees out on the way up but luckly I only took out 2 sizeable hardwoods for the entire length. Most of the rest were cedar and rolled right out. On the trip down I cut the grade level with the stab and back up method :) Turned out really good, I am not convinced the steeper slope will go so well b ut I am on top and can work my way down. The addition of a tooth bar made all the diffrence in the world!!
   / need to build a dozer style blade for my skid steer #16
Good job!
Yes, a world of difference with a tooth bar.
Whenever possible, start uphill and work your way down, the ss is much more effective with gravity helping it rather than fighting it. I've seen bulldozer operators back up a hillside so that they could work coming down.
Ken
   / need to build a dozer style blade for my skid steer #17
I can see already where I'll have to get long winded again but, any way you do it, it should be stripped of topsoil and pucker factor is a big part of that Job!
I would guess that any trail or driveway would require no more than 2 bench cuts. The second one would be your finished subgrade and should provide enough fill bring the lower one up to that grade, as you can always cut further into the backslope for more fill if necessary.
Something you absolutely must consider is drainage as a torrential downpour can take out hours of work in minutes. Been there done that more than once. Worst one lost a slope 10-12 ft deep 40-50 ft long
Basically with excavator, dig out up hill side and place on slope ahead of you to make a path ahead of your downhill track to level yourself and keep on digging. When on next bench up, spread on lower bench to bring up in layers for compacting.
With dozer, hook out an area with blade corner (or up and down the slope if not too steep) to level a starting pad then just keep working that grade through the hillside, hook it out and push it over. Tilt and angle blades help greatly. Gravity helps going downhill but I preferred to work uphill when possible where really steep, it's harder pushing but you're less likely to get in trouble. You can always back downhill but not always uphill. When we were filling the lower bench from the next step up, we usually worked 2 dozers. Big top one pushing over and smaller lower spreading the material for compaction. Many times we had to add material especially when doing embankments to flatten slopes.
Grade tolerances are quite lax when benching as the idea is to get a basically level subgrade for the fill to sit on to prevent slides.
Hope this helps
And Rio,
300 yards seems like great production for a skid steer but don't get over that edge when it gets steep. An excavator can get out of trouble by pushing itself out and dozers can generally do more than you've got pucker for, but skidsteers can hit a soft spot or something and get away in a hurry as I'm sure you're aware.
I know what you are saying is true Smiley. This streach was a cake walk compared to what is ahead. I am hoping that I can get a line picked pout on the other hill. I had a dozer operator come in and he wasnt concerned about it. Unfortunately I am not a doser operator.
Thanks for the information and help with this.
   / need to build a dozer style blade for my skid steer #19
Lots of great info in this thread. The excavator procedure is just what I did with my backhoe!
   / need to build a dozer style blade for my skid steer #20
I'm retired now and just have an old 580 Case hoe for work around the place but excavators were my favorite machine with graders second.
Here's a clip of a 375 Cat with 9 yd bucket like we had at one outfit.
[ame=http://www.youtube.com/watch?v=NPMiOXqH4Kk]Cat 375 with 9 yard bucket another day moving dirt - YouTube[/ame]
Until you actually run one and curl that bucket into the bank, you can't even begin to fathom the power in your hands. At apprx 15 tons per bucket we loaded large off road rear dumpers to overflowing with 3 buckets.
And a 390 ---- [ame=http://www.youtube.com/watch?v=RB2O7Opjb3M&feature=related]CAT 390DLME VCT and CAT 773 on A89 - YouTube[/ame]
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 TerraGator 7300 Spinner truck (A56438)
2019 TerraGator...
