Need to carry tools with me* mount box on RC okay?
   / Need to carry tools with me* mount box on RC okay? #31
</font><font color="blue" class="small">( that I frequently back it into thickets of brush and low hanging branches and would be concerned about it being ripped off the cutter or opened up accidentally and have my tools bounced out and lost before I knew about it.
)</font>
A ammo box bolted or welded to your RC is probably just as sturdy as the cutter. With their latch.. i can't imagine it coming open by accident..
Soundguy
   / Need to carry tools with me* mount box on RC okay? #32
)</font>
Soundguy
   / Need to carry tools with me* mount box on RC okay? #33
You have never seen me bush hogging /forums/images/graemlins/grin.gif I have managed to somehow bend the front and rear of my RC and an ammo box is no where near the same thickness of steel. Not trying to be a pessamist - just a realist
I could see a RC mounted ammo box working for average type, open area, hoggin though -
   / Need to carry tools with me* mount box on RC okay? #34
   / Need to carry tools with me* mount box on RC okay? #35
</font><font color="blue" class="small">( You have never seen me bush hogging I have managed to somehow bend the front and rear of my RC )</font>
I'd say that constitutes some pretty abusive use... While I don't "baby" my cutters.. I don't plow into trees intentionally with them either.
</font><font color="blue" class="small">( an ammo box is no where near the same thickness of steel. Not trying to be a pessamist - just a realist
)</font>
Well.. for 'real'.. how about mounting it away from an edge.. perhaps on a lip or ridge behind the gear box. even on a 4' mower, that should put it over a foot away from an edge... If stuff is getting damaged that far up a rotary mower.. you need more than a toolbox.. /forums/images/graemlins/confused.gif
Soundugy
   / Need to carry tools with me* mount box on RC okay? #36
)</font>
Soundugy
   / Need to carry tools with me* mount box on RC okay? #37
Soundguy,
I probably got you confused about which tractor I was talking about since my name is Fortyseven2n .
We are talking about a TO-30. I have one of those also. It has a tilting hood and the gas tank is mounted above the engine and the toolbox is located betwix the gas tank and the radiator.
My 2N has the box mounted like the pic you posted.
My JD 40-S has a tiny "toolbox" mounted in front of the battery box. Really not worth much at all.
One thing I forgot to note is that the Continental Z-129 engines on the TO-30 is prone to cracking. Make sure that the radiator is clean and the coolant is full , etc. .Also there is no position control so a Zane Thang or limiting chains are needed for bush hogging.
Fortyseven2n
   / Need to carry tools with me* mount box on RC okay? #38
Soundguy,
Fortyseven2n
   / Need to carry tools with me* mount box on RC okay? #39
I take a small toolbox with me when I go cutting. I usually carry it on the RC, between some of the bracing on top of the deck. Once I would get to where I was going to be cutting I would remove it and set it to the side somewhere.
Once last summer, I forgot to move it and started cutting. I was halfway through when I noticed it still sitting there on the deck. Now, I just leave it on.
Keep in mind, I do not cut a lot of steep slopes and the bracing is probably about 2" high. Holds the box in pretty good. I have not had any problems.
Eddie
   / Need to carry tools with me* mount box on RC okay? #40
Eddie
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
UNUSED FUTURE 10' GALVALUME COMUGATED SIDING (A57193)
UNUSED FUTURE 10'...
WOODS 9021 BATWING MOWER (A57192)
WOODS 9021 BATWING...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
