Snowman9000
Bronze Member
I have a 4' cutter on my JD 755. For a shear bolt where the PTO drive shaft connects to the gearbox, it came with a 1/2" bolt. The bolt head has no markings on it to indicate that it is high strength. It does have SJ stamped on it.
Anyway, the bolt is too stout. I have hit things that have stopped the motor, RIGHT NOW. Maybe it's because the tractor is on the small side HP wise. But whatever the reason, I need a weaker bolt.
Assuming it's just a plain steel bolt, what other ideas do you have? I can't say that I've seen brass or aluminum in half inch.
My best idea is to grind grooves in the bolt at the two spots where it needs to shear. Probably not a bad idea, but I'm open for anything else that has worked for you.
