Need Weight of the 2008 L3400HST
   / Need Weight of the 2008 L3400HST #11
Hoe, it's pretty simple. The L series are heavier than the B series. :)
My manual for the 2010 L3400 I owned listed it at 2600 lbs.
Thanks much! That seems to be the number (and I'm happy about the "extra" weight).
:reading:
I have an '08 L3400 and don't have the specs handy, but can tell you the width is closer to 60" than it is to 51.4".
Hmmm...that IS interesting. :reading: I do not like the narrower (than a B3030) widths being published. This L3400 is apparently really an '08 as well, but does not appear to have an adjustable-width rear track.
Does anyone know if the L3400 ever had an adjustable-width rear axle?
Thanks, AaronS.
Well, thankee, Bluegill2. I may just have trouble accepting good news--LOL. Weight is GREAT!
   / Need Weight of the 2008 L3400HST #15
:reading:
Thanks, AaronS.
Width is adjustable if you have Ag tires, you can flip both the inner disc and the outer rims to vary the overall width. Mine with Ag tires will go as wide as 60" outside to outside, center track of tires is 48".
They are narrow, no question about it. Not the best tractor choice if you have a lot of side hills you plan on using it on, although they are nimble around the woods and between trees.
2600 lbs. is about right, which is light weight for a 35 hp tractor. Without 4wd they wouldn't be much good for ground engaging jobs, snow removal, etc.
Sean
   / Need Weight of the 2008 L3400HST #16
Sean
And with R4 industrial tires it is not adjustable. I am not sure about R3 turf tires.
   / Need Weight of the 2008 L3400HST #17
:reading:
Thanks, AaronS.
Happy to help. My 60" rotary cutter covers the rear R4's, but not with much room to spare.
   / Need Weight of the 2008 L3400HST #18
:reading:
Thanks, AaronS.
Wheel spacers will get ya a wider stance...
Yes, wheel spacers are definitely on the list--also because I want chains for the (wider than R4's?) turfs I want.
Thanks again.
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
Enclosed 16ft S/A Cargo Trailer (A51694)
Enclosed 16ft S/A...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
