Need Wood Stove Advice
   / Need Wood Stove Advice
Thanks guys - lots of good ideas to think about.
I spent a lot of my youth cutting, splitting & feeding oak to a Vermont Castings Vigilant - it was a great stove. I'll have to see what's out there on CL. My impression is The Plant Manager wants something new, rather than old, but I'll have to see how firm that position is.
Was reading about the Jotul f 50 tl Rangeley, which seems to fit most of my requirements and is very efficient & clean, but man, that thing is expensive. I guess it's not much compared to a new oil furnace, but I'm still geting over the sticker shock.
Someone at work had also suggested that the smoke may have been from inadequate fresh air supply, so I will investigate that, too. But I'm pretty sure there's a breach in the firebox somewhhere as the throttle doesn't control the burn rate very well. I think the breach opens up some when the stove heats up, making the stove run too hot.
Will check out the Alaska & Lopi stoves.
Thanks for the Hearth.com forums suggestion!
I'm going to pass on the furnace for the present - seems like too much work to install and find a way to get the smoke above the roofline.
   / Need Wood Stove Advice #12
If I understand correctly, you are going to have this in the basement? If so, I strongly recommend a wood furnace so that you can duct the heat upstairs.
When we bought this house ten years ago, it had a US Stove Hotblast 1200 (Tractor Supply) in the basement but no ducting. It kept the basement plenty warm (too hot!) but did a poor job of getting the heat upstairs even though there was an open stairwell ten feet away. When I finally ran a single duct upstairs, WOW! the difference it made.
Four years ago, we put in a modern, efficient EPA type stove upstairs (Pacific Engineering Summit). We love it! It uses a lot less wood, has a glass door which makes the fire much more enjoyable. If you are going with a stove instead of a furnace, I highly recommend it as a great unit. But, as others have said, read hearth.com for a while. They also have reviews of individual stove models over there.
I agree with you, avoid the pellet stoves, especially if you can cut your own firewood.
Ken
   / Need Wood Stove Advice #13
:confused: not really sure what you mean by the smoke above the roof line. No matter which stove you install you'll need to safely move the smoke???
I've also seen the furnaces run in many different ways/configurations, they can be as easy or as hard as you wish to hook up. There is a fellow up the road that has one set in his back room with a 90degree elbow aimed where he wants his heat to travel, No piping except the elbow. He keeps his house close to 90F all winter long. This is also his only source of heat.
   / Need Wood Stove Advice #14
tollster mentioned coal, have you given that a thought?
there was a recent thread about coal burners, (i was one)
and you can find many manufacturers and styles, from
stokers to hand fed, to full furnaces. the coal advantages
are no handling/splitting wood, (if you have it for free, then
obviously that's best), and higher btu output, very efficient
heat, and a much more constant heat for long burn times.
i used a hand fed for 8 winters here in upstate ny, which meant
twice a day i had to load/shake the stove, which was located in
our basement of a ranch house. kept both levels nice and warm
on about 4-5 ton per year average. (certainly not close to that
this past winter)
there is a great forum for that also:
Northeastern Pennsylvania Community Forums, Home of the Anthracite and Bituminous Coal Forums
I already have a central chimney which is how I get the wood stove smoke out of the basement and up above the roofline. I sure don't want to run a flue into the house to get it up the chimney. I also don't want to hook my hot water heat system up to it and then have to run an electric pump to circulate the heat 24/7, nor do I want forced hot air. I also don't want a furnace sitting in my back yard. I want to replace the present stove in the basement. A high quality, long burn time, efficient wood stove is what I want.
this past winter)
Thanks, but no, not interested in buying coal when I have acres of hardwood that provides me with ample fuel. Coal is a commodity, just like fuel oil. I'm trying to avoid reliance on commodity fuels by burning home grown. There is also a carbon footprint aspect to this, but that's another topic, entirely.
   / Need Wood Stove Advice #17
I think I understand your setup and it's similar to my situation except my house is two stories which complicates things, but I have forced air which helps. I added vents with dampers above the stove, cut into my furnace return air ducts to help distribute the heat. My problem with that is that it further aggravates my negative pressure problem in the basement, so I have to make sure I close them if the stove isn't hot.
I have only a small stove (36K/72K rated BTU) because any larger one would make the basement uncomfortably warm, even with the ability to move the air.
As you get into this project, I would suggest you look into the potential of adding some air circulation capability. For instance, If you can make a return duct in an interior wall by adding a grille and hooking into the cavity in the basement, you can add a high capacity (say 200 to 300 cfm) in line bathroom fan to bring upstairs air into the basement. This will have the dual advantage of pressurizing the basement to minimize any smoke spillage and will also force more hot air up the stairs. This won't be a lot of additional cost and I think the system would work a lot better if you have a large stove in the basement.
   / Need Wood Stove Advice #18
The wood furnace I am writting about would be able to hook into the existing chimney same as wood stove. It has a long burn time 6-8-12hrs depending on how hot one would want it. BUT I see you say no forced hot air so I quess it would be out. If you don't mind me asking why no forced air? Everyone around here that has switched over to the furnace wood stove is VERY happy they did. Here is a link to the type of wood stove I'm suggesting Englander Add-On Wood Furnace it's not very big as you can see from the dimensions. It is made to be in the house without taking up any more room then an average woodstove and IMO is safer. I can touch all sides of mine(not the front) when there is a fire going.
   / Need Wood Stove Advice #19
We just finished our third year with our Napoleon wood stove. :thumbsup:
I really like it. EPA rated. No catalyst. Good burn times with good wood. When it is burning well, ZERO smoke from chimney. :thumbsup:
Last year I ran it for 6 months straight and I beleive I only let it go out 4 times. Just kept feeding it. I empty the ash pan about once every two weeks.
Well worth a look if you have a local dealer. :)
Napoleon Wood burning Stoves
   / Need Wood Stove Advice #20
You should have said this in the first place then..
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
