Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #1
dwiegand
Palestine Texas
DK 45 Kioti Tractor
If anyone out there has either a crank shaft or a complete engine for a Kioti DK 45 Engine model number is A4220, PLEASE give me a call or email me at dwiegand07@gmail.com. Crankshaft for. DK 40 is the same.. You can also call or text me 903 948 8611
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #2
What'd you do?
What'd you do?
Spun a crankshaft bearing on #1 cyclinder.
Need either an engine or a good used crankshaft. Can either be out of a DK 45 or DK 40. Both engines A4200 and A4200 use the same crankshaft. 903 948 8611
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #4
First thing is to find out if oversize bearings are offered in the 0.010", 0.020", 0.030" oversize. Take your crankshaft to a good crankshaft grinder. They will inspect the crank to be sure it is straight, and can be reground. A very good engine machine shop can usually find a bearing match also if Kioti doesn't offer oversize bearing.
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
20ft Utility Cargo Trailer (A51572)
20ft Utility Cargo...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
