Needing some serious help
   / Needing some serious help #11
I am not sure on how to disconnect. The only John Deere I ever had to hook up to was a 4020 and that was 30 years ago. Seams like we had to push down on that lever and the hose would just pop out. Sorry I can't be more help.
   / Needing some serious help #12
Looks to me like two way couplers in a housing.
Meaning you push your hose in and it locks. You simply pull on the hose to disconnect.....because the coupler is mounted by the collar.
Its called breakaway protection. Incase you drive away from something and forget to unhook the hoses.
I am guessing when you "thought" it was connected.....and you pulled on it and it came back out......I am betting it was indeed connected and working just fine. Simply pulling on it is how to disconnect
Nearly what happened, while I was trying to hook it up, the sleeve went back in. carefully pulled it back out with a flat head and everything is working now. thanks
Chariot 12' Inclosed Trailer (A50515)
Chariot 12'...
2013 Ford F-550 4x4 Altec AT40M 40ft Bucket Truck (A50323)
2013 Ford F-550...
Feed Bin (A50515)
Feed Bin (A50515)
2013 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2013 Freightliner...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
