Neighbours Poulan Won't Run?
   / Neighbours Poulan Won't Run? #11
Go get a carb rebuild kit. Not knowing this particular model I can't go much more. I had a bad reed valve that caused sort of the same problem.
The kits are real basic.....really just a diaphram.
Also the fuel line could be bad and be sucking air. I have had this happen with sort of the same symptoms.
The one's I have dealt with have Walbro Carbs and Ebay has lots of parts for them.
   / Neighbours Poulan Won't Run? #12
I had 2 poulans that lasted about 10 years each ... then I bought this last one and I can't get the bloody thing to run....haven't worked on it much yet -- no time -- but I needed a saw pronto and one that would run so now I have a Husky rancher and so far I really like it. Maybe I'll just sell the poulan at a garage sale.
   / Neighbours Poulan Won't Run? #13
I spoke too soon. :eek: Mine was running when I used it last Fall, but now the fuel lines are shot. It's about 14 years old anyway.
   / Neighbours Poulan Won't Run? #14
My neighbour has a Poulan Black Hawk Bh 2660 42c.c., 18" chain saw. It starts ok, will idle, then when you start cutting it will die. I haven't tried it yet, but anything I should look at? He said the air filter is clean, new spark plug and the oil gas mixture is 40:1 the same as he said he's always used. I have no experience with this brand.
I'd like to try and help him, as they are kinda low on funds.
Remove the fuel cap empty the tank, and look inside the tank I think youll see that the filter is at the bottom and the fuel pickup line is broken and deteriorated.
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2006 Intellistrobe AFAD Trailer (A52377)
2006 Intellistrobe...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
FRUITLAND RCF 500 VACUUM PUMP UNIT (A53843)
FRUITLAND RCF 500...
ACETYLENE TORCH CART WITH GAUGES AND HOSES (A53843)
ACETYLENE TORCH...
