Neutral Safety Switch
   / Neutral Safety Switch #1
solakian
I have a Hindustan tractor that needs a Neutral Safety Switch. This tractor was never "officially" imported into the U.S. and there are no dealers.
The neutral safety switch has a 3/4-14 thread, the threaded portion is slightly under 1/2" from the shoulder to the tip, and a ball extends beyond the threaded portion to ride on the shift rail. The switch is normally open (ball extended), and I can adapt almost any type of connector.
Can someone help me identify a swith that will work for my tractor?
   / Neutral Safety Switch #2
I can't help you match a switch, but if you can't find a match for the transmission, you can build a mount and mount any two pole NO ball switch for the clutch pedal to close when the pedal is depressed.
   / Neutral Safety Switch #3
Just replaced a safety switch on my Kubota. Check-out a dealer they may have a replacement switch that will work for you.
   / Neutral Safety Switch #4
3/4-14 is not a standard thread size. I suggest this may be a 3/4-16 thread or a metric size.Since it's an Indian tractor, I'd lean toward the metric thread (probably an 18 or 20 mm. both 18 and 20 mm are standard metric thread sizes).
Don't force a fitting into a threaded hole. You'll strip the threads.
I'd try a Mahindra dealer. That's an Indian built tractor, so they may have the parts you need.
   / Neutral Safety Switch #5
Check out a Chevy truck with a Muncie 4 speed sounds like the reverse switch
or the ford 3000 my neighbor had had one similar on top of transmission housing
napa has a picturial catalog of their switches try them too
tommu
   / Neutral Safety Switch #6
Check out John Deere part # CH13415
(no idea what thread size it is)
   / Neutral Safety Switch #7
What's wrong with the switch you have? Can it be rebuilt or cleaned up to make it work.
I've had to fab a number of parts when the replacement is unavailable or impractical.
   / Neutral Safety Switch #8
The neutral safety switch on a 100 series Massey is about that size and worked the same. Check one out for a MF 135 to see if it works.
the switch I have was wired into the high current side of the starter circuit. It is a sealed unit but I suspect the contacts have arced one time to many.
   / Neutral Safety Switch #10
the ford tractor ones were like that a push button on top of the transmission
I think it grounded out to to work the starter
tommu
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
