Neutral Safety Switch
/ Neutral Safety Switch #1
solakian
I have a Hindustan tractor that needs a Neutral Safety Switch. This tractor was never "officially" imported into the U.S. and there are no dealers.
The neutral safety switch has a 3/4-14 thread, the threaded portion is slightly under 1/2" from the shoulder to the tip, and a ball extends beyond the threaded portion to ride on the shift rail. The switch is normally open (ball extended), and I can adapt almost any type of connector.
Can someone help me identify a swith that will work for my tractor?
/ Neutral Safety Switch #2
I can't help you match a switch, but if you can't find a match for the transmission, you can build a mount and mount any two pole NO ball switch for the clutch pedal to close when the pedal is depressed.
/ Neutral Safety Switch #3
Just replaced a safety switch on my Kubota. Check-out a dealer they may have a replacement switch that will work for you.
/ Neutral Safety Switch #4
3/4-14 is not a standard thread size. I suggest this may be a 3/4-16 thread or a metric size.Since it's an Indian tractor, I'd lean toward the metric thread (probably an 18 or 20 mm. both 18 and 20 mm are standard metric thread sizes).
Don't force a fitting into a threaded hole. You'll strip the threads.
I'd try a Mahindra dealer. That's an Indian built tractor, so they may have the parts you need.
/ Neutral Safety Switch #5
Check out a Chevy truck with a Muncie 4 speed sounds like the reverse switch
or the ford 3000 my neighbor had had one similar on top of transmission housing
napa has a picturial catalog of their switches try them too
tommu
/ Neutral Safety Switch #6
Check out John Deere part # CH13415
(no idea what thread size it is)
/ Neutral Safety Switch #7
What's wrong with the switch you have? Can it be rebuilt or cleaned up to make it work.
I've had to fab a number of parts when the replacement is unavailable or impractical.
/ Neutral Safety Switch #8
The neutral safety switch on a 100 series Massey is about that size and worked the same. Check one out for a MF 135 to see if it works.
the switch I have was wired into the high current side of the starter circuit. It is a sealed unit but I suspect the contacts have arced one time to many.
/ Neutral Safety Switch #10
the ford tractor ones were like that a push button on top of the transmission
I think it grounded out to to work the starter
tommu
Thanks to all for your suggestions. I erred in the original post, the thread was a 3/4-16 (not a 3/4-14 as I stated). The suggestion made, that a Massey Furgeson 135 had a similar switch was right on. In my travels, I drove by a Massey dealer. I pulled in, had them look up the switch, they had it in stock, and it was just what I needed. The terminals were made for bullet not spade connectors, but that was a minor problem easily overcome.
/ Neutral Safety Switch #13
When you say the high current side of the starter circuit do you mean the large diameter wire that comes from the battery? If so that is wild to switch that amount of current. Very poor design when you can switch the low amp circuit to the solenoid.
/ Neutral Safety Switch #14
My Massey ferguson 1440 Neutral Safety switch is acting up too. Does anyone have schematics or sound advice on getting access to it to fix or replace? I am snowed in and can't get it to a dealer so I need to be "creative"
/ Neutral Safety Switch #15
MF parts catalogs are online for free, sign in as a guest.
AGCO Parts Books
/ Neutral Safety Switch #16
If it's like the switch on my MF135 diesel, just jumper it until you can get a replacement. Be sure the tranny's in neutral before you start the engine.
Good luck
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2023 Case TV450B (A62177)
2023 Case TV450B...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
