Oil & Fuel Never idle a diesel??..
   / Never idle a diesel??.. #1
r0GuE
West PA
ex-Bota Owner
I'd like to check on the accuracy of a statement made to me by a guy who used to work at a trucking company and seems to know about diesels etc.
He claims that you should never low idle a diesel because the fuel does not atomize properly and therefore condenses on the cylinder walls interfering with proper lubrication.
His recommendation is to start the tractor and immediately move it to 1000 - 1500 RPM (I have a BX so this setting would be an estimate).
I know I've heard of truckers idling their rigs all night, but he said that is because they are afraid they won't be able to restart them and they also need the power for heat etc. Besides, it's usually not their rig and the rig has extra lube equipment etc. But for a small tractor, he recommends no idling.
So what do you all think about this.
Also, Happy Holidays to all!
Rogue
   / Never idle a diesel??.. #2
Wow, that would be news to me. I thought that was one of the plusses for deisels that they were able to idle for long periods of time. My brother in law, who works at the GM proving grounds in the military division in Michigan, used to leave his diesel Suburban idle when the weather was really cold while he was at work. I guess with no plugs available he was afraid he would not be able to start it.
I have a B7500 and I thought it idled kinda high. I believe it sits at about 1100 rpm. Is this too high, does anyone know the spec for this adjustment?
Jeff
   / Never idle a diesel??.. #3
That post is true and it isn't true. Big rigs don't let them idle all night so they can start them the next day, although yes that can be true on really cold nights. Unless they are stopped for the night they let them idle. Anyway the point is that yes at a constant slow idle speed after about 10 minutes all of the fuel will not burn and it does cause deposits. What big rigs and even my pickup have is what is called an auxillary idle controller that automatically varies the speed of idle so that you don't get the deposits. It's still good practice to idle a diesel if it is going to be less than 10 or 15 minutes. If it's more than 10 minutes just bump up the idle to a higher speed and you won't have to worry about it. That's also why you see alot of guys get on their tractor after it has been idling and rev it up a few times to get the unburned deposits out of it.
   / Never idle a diesel??.. #4
When she's puffing a little blue on startup at 8500 hours you can wonder if maybe you idled her too much in the last 30 years... /w3tcompact/icons/smile.gif...
Isn't diesel a bit of a lubricant anyway? Diesel's have less top-wear than gas engines, and the only worn out small gas engines I've seen had plugged cooling fins. I wouldn't worry about it.
- Patrick W.
   / Never idle a diesel??.. #5
<font color=blue>Isn't diesel a bit of a lubricant anyway?</font color=blue>
Based upon my experience walking on the concrete pad where my local diesel pumps are, I'd say it's a great lubricant! /w3tcompact/icons/shocked.gif
   / Never idle a diesel??.. #6
IF THE TRACTOR IS GOING TO IDLE FOR MORE THAN 5+ MIN. I TURN IT OFF. I DON'T FEEL LIKE BREATHING ANY MORE DIESEL THAN I HAVE TOO. BUT THEN AGAIN, IF YOU LOVE THE SMELL OF DIESEL IN THE MORNING - LET HER RUN!
   / Never idle a diesel??.. #7
There have been a number of postings regarding this in the past and after reading them, I have decided that if the tractor is going to sit unused for brief periods of time it is better to let the engine run than to submit the starter to the extra stress and wear of several restarts. However, I always idle my little John Deere at 1,300 RPMs so that there is adequate oil lubrication. A number of postings in the past indicated that there might not be adequate lubrication at 800 RPMs. When I start the tractor in the morning I let it idle at 800 RPMs for a minute or two so that the oil has had a chance to circulate throughout the system; then I increase the speed to 1,300 RPMs and I don't operate the tractor until the needle on the heat guage moves into the operating zone. This takes a bit of time so I usually take along my last early-morning cup of coffee and stand and admire the tractor and feel grateful that I have it. That green and yellow sure is a pretty color combination. By the way, when I finish work for the day and put the tractor in the garage, I decrease the RPMs to 800 and let the tractor sit for a minute or two until the needle on the heat guage drops to its lowest position before turning off the engine. I don't really know if all of this is necessary, but it's what I've gleaned from past postings. Even if I didn't do these things the tractor would probably run just fine and outlast me by many years; however, it gives me pleasure to feel that I am doing my best to take care of the tractor.
   / Never idle a diesel??.. #8
Most newer Kubota's will idle over 1000 rpm, they do this so they can meet air standards. This makes me believe there is something to the statement about unburnt fuel mixing with the oil.
   / Never idle a diesel??.. #9
i usually start mine at about 1000 to 1200 rpm and let it idle there till it warms up. when in use if i am off machine for more than 10 min. i shut it down other than that i let it idle at abot 1000. i don't think u can hurt it much either way, for the no. of hours most of us use our tractors.
   / Never idle a diesel??.. #10
I think this is an area rampant with myth and wive's tales. To me the most credible source of information available to most, if not all of us is your owner's manual. My recollection is that it says nothing about the hazards of idling the engine. It does specify an idle speed (at least in the workshop manual) and I think that's the speed the idle should be adjusted to.
Unless you are getting advise from a deisel engine design engineer from Cat or Kubota or Cummins or the like, I would question whether you have a source of advice more qualified than your manuals.
A couple of other things to consider:
If idling for extended periods of time were a problem, wouldn't the manual say not to do it?
When was the last time you had trouble starting your deisel?
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
John Deere 7130 (A53314)
John Deere 7130...
2015 Ram 5500 IMT 3203i 4,000lb 2 Ton Crane Service Truck (A55852)
2015 Ram 5500 IMT...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
