New 2520 arrived, put right to work
   / New 2520 arrived, put right to work #21
The tiller will be great for ballast. :thumbsup: A ballast box is a good idea though, then you have a fair amount of weight in a compact area.
   / New 2520 arrived, put right to work #22
doabbs said:
I got the independent lift kit so the 3PH isn't what lifts the mower deck. Should I still move the tires to the wide offset?
Most definitely. That's the same setup I have and I have grooves in my tires because the dealer didn't swap them like I asked them to. The lift mechanism has some side play and the pins that attach to the lift arms will hit the tires.
Be careful if you try to swap them yourself. Besides the tires being very heavy, it takes two jacks to pick up the rear of the tractor and keep it from tipping sideways as it will pivot on the front axle.
I don't understand why the dealers don't just routinely set the rear tires up in the wide position when they set up the tractor.
   / New 2520 arrived, put right to work #23
If this is your only concern, you can get some spacers that fit on the support rod and prevent it from hitting the tires.
Some people want a narrow tractor for maneuverability. I have rear tires in wide position *and* 1" wheel spacers...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2020 Deere 325G (A50123)
2020 Deere 325G...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A52377)
2013 GMC Sierra...
