new 2720 on the way
   / new 2720 on the way #11
Do these new tractors not have any kind of a mechanical stop for the mower deck position? I have the independent lift cylinder on my 755, but also have a knob on the center floor to set how far down the deck lowers. It is an easily adjusted mechanical stop. When I am using the FEL, I just raise the deck and set the knob to lock it in full up position. No separate valves required. If there is no stop on the new ones I agree it would be a real pain to keep the deck in position without using the 3PH instead.
The 2305 and 2320 do, while the 2520 and 2720 do not.
   / new 2720 on the way #14
It's not a big deal,and I really don't miss not having one. Just set the little rockshaft stop and you're GTG!:thumbsup:
How do you keep the mower deck raised when you want to use the 3PH for something else?
   / new 2720 on the way #15
Even the 2320 is a pain. When you're mowing a field and you want the deck in its highest position you can't lock it there and it constantly drops even if yuo set the knob.
   / new 2720 on the way #16
If I use the 3pt for something else,I remove the deck.:)
One of these days,I'll get around to making brackets to hold it up.
Greg
   / new 2720 on the way #17
Greg
Nice BB Greg!
   / new 2720 on the way #18
There is an optional "Deck Lock up Kit" available from JD for the 2520/2720 which allows you to mechanically lock the deck up, and still use the 3pth independently. It consists of 2 brackets that are mounted at the rear of the tractor near the 3pth arms, and 2 chains with turnbuckles, that fasten to the brackets and the deck lifting bracket, so you can adjust them. This set up will hold the deck up mechanically and still let you use the 3pth arms independently. I have a 54" blade for the snow, and I wanted to be able to hold up the deck arms independently, because I will also be using a ballast box in the winter for additional traction, and don't want to have to keep the box at the highest position when plowing snow.
Sort of a mickey mouse system, I thought it was going to be some sort of lever thingy that I could operate from the seat of the tractor, but no, just a set of "Limit Chains" that you have to pin to the brackets. It works, but as I said, kind of a mickey mouse deal, especially since here in Canada the kit cost me about $180.
I have a 2520 and ordered this kit with the tractor because I also wanted to be able to use the FEL while the deck was on, and didn't want to have to change lines from the FEL/Mower deck to the SCV ports, which you have to do if you have the independent lift kit, without the diverter vavle.
If you want to go with the independent lift kit and still use the FEL at the same time as the mower deck, you need to install the hydraulic diverter valve, which gives you 2 additional hydraulic connectors, and a push/pull control valve which is mounted on the lower right side of the operator station. This lets you keep all 6 lines connected at the same time.
By using the regular 3pth to lift the deck, you don't need the independent lift kit or the diverter valve so you can leave the 4 FEL lines hooked up all the time. Heck of a lot cheaper, especially when I read that the independent lift cylinder has a tendancy to leak down on it's own. Sure glad I went the way I did, would have cost me at least another $1200 to go with the Independent lift and diverter valve. I would have been some PO'd if after spending all that loot the thing still leaked down on it's own. Hey $180 sounds pretty cheap now that I think about it.
REV
   / new 2720 on the way #19
Still hard to understand why Deere got away from the simple knob adjustable mechanical stop. No leakdown, no link chains, no diverter valves, most convenient, and probably lowest cost.
REV
I am thinking I made the mistake of getting the independent lift, based on what I read here it seems the 3point hitch lifting system saves a lot of time. I was also told with the hydraulic lifting system you loose one funtion on the FEL which I am sure suck. My 2720 should be here in 2 weeks I think, so I will deal with all that then
Wooden
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
23169 (A50324)
23169 (A50324)
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Year: 2007 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 147,891 Plate: Body Type: 4 (A55788)
Year: 2007 Make...
