New 4110
   / New 4110 #1
tld
Boston, GA
JD 2025r
Just took delivery of my new JD 4110 with BH RD60 finish mower. Prior to delivery they had to put about 200 lb of wieght in the front to balance it out. Even now when I raise the mower too fast it almost takes the wheels off the ground.
Is this mower too much for this tractor?
   / New 4110 #2
No. Most compact tractors without FEL will require front end weights with a rear mower. It sounds as if you may need a little more front end weight. With my old B7100 I usually added about 150lbs without FEL.
   / New 4110 #3
I put 165 pounds on the nose of my B-7500 to counter balance my Woods RD 6000. The tractor handles the mower just fine and if memory serves your tractor is the same HP and PTO HP as mine. Good luck have fun and enjoy that new tractor./w3tcompact/icons/grin.gif
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
IH 470 Disk (A50515)
