_RaT_
Super Member
- Joined
- Apr 19, 2000
- Messages
- 5,813
- Location
- Peoples Republic of Northern CA.
- Tractor
- Kioti 3510-SE HST
As I understand, the pressure is regulated at the access panel under the seat. I don't need to tell you, the difference in build between a LA 853 and JD 460 should be more then obvious. For that matter, between a LA 723 and JD 430. Do know that we are also talking about considerably different dump/curl angles. Nonetheless, do a simple check yourself. Get a male quick connect to the front curl or dump quick coupler, a 5000 PSI gauge and test the pressure yourself. If it's off, adding a shim or two should do the trick as I am told. I have mine set at +/- 2600 PSI within a few PSI. It will pick up a JD 4310, 430 loader and all. In fact, it may well hurl it clean over to the RockyRidges of Oklahoma from the gracefull foothills of Northern California.
I think of OK as flat. Not that there is anything wrong with that.
