New 4710 Came Home Yesterday
   / New 4710 Came Home Yesterday
Top and tilt hydraulics will provide greater flexibility at the 3PH.
Frontier medium duty landscape rake...6ft
   / New 4710 Came Home Yesterday #23
Rancar,
Thanks for sharing the pics, they all look great. I would like to see some action shots of the 4in1. Congratulations on your new equipment, looks like you got everything right upfront. Is there anything else on your wishlist?
Oops, I forgot to ask, what horsepower is the 4710?
Finally, the same Frontier 1172 landscape rake with grader blade folded down. Note boot cap ends that transform rake into sort of a modified box blade alternative for simple grading tasks.
Spencer,
Will post action shots as projects unfold in the coming weeks. It's been kind of muddy here over the past week and I'll will wait until Memorial Day weekend to put the 4in1 to the test.
I appreciate your posts of about 6 weeks ago where you used your forks for stump pulling. I bought mine based on your nifty technique that you clearly demonstrated. Mine don't have the lift capacity of yours but nevertheless I think I'll try it on some of the smaller stumps as well as lifting and transporting many large flat fieldstones I have.
In time, I would like to get a post hole digger and sickle bar mower. Further down on the list due to expense is the JD model 48 backhoe and maybe a real box blade.
The 4710 is 48HP, 4 cylinder engine and about 40.5 at the PTO.
Bob
   / New 4710 Came Home Yesterday #26
Rancar,
Congrats on the machine,looks like you really thought it through and got just what you wanted,it just looks like its lookin for something to dig,pile,grade,and mow.I really like the HD toothbar and want to get one for my machine when I get it,thanks for the pics and best of luck to you and your new toy....uhhh....I mean valuable piece of equipment that gets lots of "jobs" done around the homestead! /w3tcompact/icons/wink.gif
   / New 4710 Came Home Yesterday #27
Great looking setup you've got there Bob! I suspect you'll have lots of fun... er, productivity with all that /w3tcompact/icons/wink.gif I take it the dealer did the TnT for you? Where is the control valving? Any chance of a picture of that?
Interesting rake/blade combo. I've not seen one like that. Be sure to let us all know how it works for you /w3tcompact/icons/smile.gif
   / New 4710 Came Home Yesterday #28
Hi Bob...
Picture perfect... /w3tcompact/icons/blush.gif Did you have to mow your field in the background to get that beautiful "calendar" picture.../w3tcompact/icons/wink.gif
Congrats again Bob... /w3tcompact/icons/smile.gif
   / New 4710 Came Home Yesterday #29
Bob...
Quick tip... on storage of your implements outside (like your rotary cutter)... try to keep ground contact minimal... prop the skid plates up/away from the ground/dirt/water... (helps prevent corrosion... /w3tcompact/icons/smile.gif)
(also after each usage... knock the major dirt/debris/mud/sticks off the implement... dirt holds moisture and we all know what moisture does long term...)
   / New 4710 Came Home Yesterday #30
Congrats on the new tractor and implements.......now lets get them dirty!!!!!!!
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
Case Titan 3530 (A56435)
Case Titan 3530...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2016 Freightliner Derrick Digger Truck (A55973)
2016 Freightliner...
